586,648 active members*
2,832 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese 3 Phase 3KW VFD spindle Settings needed after reset
Results 1 to 6 of 6
    Mar 2013
    6
    Lightbulb Chinese 3 Phase 3KW VFD spindle Settings needed after reset
    I own a 3KW 3 Phase chinese Spindle, a EYS8043-18/3.0 spindle
    It has 2 Poles, 3 Phase, 300Hz, 8.6A, 3 Kw, 18000 R/min.
    the VFD is a 220V 3KW Vfd supplied with the spindle. I accidently factory reset and cannot get the settings right anymore, the manual has nothing but the VFD factory settings not related at all to the spindle.
    Attachment 462060Attachment 462062Attachment 462064
    15362
    Re: Chinese 3 Phase 3KW VFD spindle Settings needed after reset
    Quote Originally Posted by casperround View Post
    This is quit straight forward, don't keep trying it or you will smoke the spindle
    I'm guessing this is an air cooled spindle, doing a factory reset did not change anything as all VFD Drives are at factory Default when you get them
    So need to know the make / manufacture and model of the VFD Drive
    What are the Parameters first 2 Letters
    Mactec54
    Mar 2013
    6
    Written on the side of the VFD are these:
    HY03D023B
    2PH AC 220 + 20% 50Hz + 5Hz
    3PH 0-220AC 3KW 13A 0.50 * 400.00Hz
    400 - 606 - 8887
    Yes it is a 3KW Air cooled spindle.
    15362
    HY03D023B
    400 - 606 - 8887
    What are the Parameters first 2 Letters Is it ( PD ) this will tell me if you have a genuine HY VFD Drive there are may HY copies and have different Parameter settings
    Mactec54
    Mar 2013
    6
    Sorry, yes in the VFD settings it is PD
    15362
    This should get you going this is a full set there may need to be some adjustments
    Huanyang Mactec54
    Input Power Connection Single Phase
    Terminals R and T Plus Ground
    3Kw Air Cooled 18,000 RPM
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=300
    PD004=300
    PD005=300
    PD006=90
    PD007=20
    PD008=220
    PD009=66
    PD010=15
    PD011=120 ( This may need to have a higher Minimum Speed for your Spindle watch Temperature )
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014=10 ( Acceleration Adjust to suit)
    PD015=10 (Deceleration Adjust to suit)
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM 18,000)
    PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD072=300
    PD073=120 ( This may need to have a higher Minimum Speed for your Spindle watch Temperature )
    PD120=120 (Stall Prevention )
    PD174=13 ( Your VFD Drives Max Amp Output Rating )
    If Minimum Speed is changed then other Parameters will need to be changed also, Your Minimum Speed is related to the temperature of your Spindle to low and it will over heat
    Mactec54
  1. Replies: 78
    Last Post: 05-02-2017, 12:48 PM
  2. 3kw Chinese Spindle, Is it really 3kw
    By bd007 in forum DIY CNC Router Table Machines
    Last Post: 12-10-2014, 09:05 AM
  3. 3kw spindle on a 4kw vfd
    By Bl@ckrat in forum DIY CNC Router Table Machines
    Last Post: 08-08-2014, 10:47 PM
  4. Chinese 3KW spindle + Hitachi VFD question
    By mercaytor in forum DIY CNC Router Table Machines
    Last Post: 11-28-2013, 02:57 AM
  5. Replies: 0
    Last Post: 05-11-2011, 12:00 AM
