586,551 active members*
3,399 visitors online*
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Jan 2018
    1516
    Re: Servo Drive Controls I/O
    It's called active low and is very common in industrial control hence servo manufacturers tend to use it.
    Craig
    I'm beginning to learn At least it was something simple and not a costly mistake.
    Well. Thanks again for helping me out Craig.
    Next thing is..... The box. You don't realise how big some of the equipment is until you lay it out on the base plate.
    600x600 box is actually a bit small. Going to have to stack some of the components if I want it all in there to futureproof it.
    Not ideal.
    At least it has a decent 300mm height.
    Darren.
  2. #42
    Nov 2013
    4431
    box????....Oh Yeah, I was going to make one of those....but I just got so busy.....I ended up nailing and/or screwing the boards to a piece of MDF and got on with the job at hand. Been like that for
    six years, haven't had to pry out any electrocuted toddlers, pets, neighbours, neighbours pets....Shame really, there is one neighbour for whom electrocution is too good....but I digress.
    My new build mill will hopefully be a bit better.
    The motion control board, the BoB's (2),the level translator IO board and the step/dir differential board are screwed to a 250mm x 400mm plastic chopping board/breadboard.
    So when I say I've breadboarded my control system I bloody well mean it!!!
    Craig
  3. #43
    Jan 2018
    1516
    Craig
    Craig. You really do crack me up!.
    I'm laughing and crying at the same time.
    Why didn't I think of the chopping board.
    Darren.
  4. #44
    Jan 2018
    1516
    I was of the opinion the DO's were opto-transistor outputs, that is to say they are neither high or low until or unless you apply power,
    so are rather either conducting or non-conducting.
    Craig
    Hi Craig.
    Sorry about this but I want to pick your brain again.
    Everything seems to work perfectly but I'm not convinced on Lichuan's wiring diagram when it comes to the mains input.
    They have it so that both main & control power come out of the filter straight into the servo. What is the point of having the 'servo ready' fault then if they both go off together?.
    I figure that the main power line should be run through a contactor seperately so that the main power can kill the motor but leave the control power entact
    For instance... an estop (or other fault elsewhere) triggers contact - shuts off the main motor power - control power still exists to say there's an alarm condition.
    To my mind this sounds more logical. Yes?
    Daz.
  5. #45
    15362
    Quote Originally Posted by dazp1976 View Post
    Hi Craig.
    Daz.
    The way you are thinking, is how it is normally done
    Mactec54
  6. #46
    Jan 2018
    1516
    Thank you for clearing that up.
    Daz
  7. #47
    Mar 2021
    Daz
    Hi Daz, I have the same setup and in need of a bit of help. I’ve sent a pm to you. Pls look at it.
    Thanks, Poul
Page 3 of 3 123
  1. SERVO-ON, ALARM RESET, SERVO READY CONTROLS WHAT TO DO?
    By quickjam in forum Servo Motors / Drives
    Last Post: 10-24-2021, 11:01 AM
  2. Replies: 5
    Last Post: 03-17-2016, 10:11 PM
  3. Replies: 0
    Last Post: 01-20-2015, 01:28 AM
  4. Replacing Floppy Drive on Machine Controls
    By ObrienDave in forum DNC Problems and Solutions
    Last Post: 08-01-2005, 02:29 AM
  5. HELP Need mazatrol servo controls
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2005, 09:19 PM
