586,121 active members*
3,509 visitors online*
    Issues sending jobs
    Hi
    sorry i am new to these machines and cnc in general
    i am using nclite to send jobs to the machines and basically it has stopped now
    it seems to transmit ok, but there is nothing on the other end on the machine.
    is there some kind of ready/go state to progress it.
    ive tried all kinds of comms settings, but that doesnt seem to matter
    im using usb to serial, which has ethernet (long connection) into machine
    ive tried db9 to db25 2m also. same results
    its happening on both the mill and lathe.
    Re: Issues sending jobs
    SL40 Lathe & TL1 Mill
    Mar 2010
    1852
    Go to the bottom of the programs list and select "All" and hit "Rec RS232" on the panel.
  1. Issues Duplicating Lines of Code when sending through RS-232
    By cncsuper in forum USB, RS232, PARALLEL etc
    Last Post: 10-12-2020, 01:27 AM
  2. Sending jobs to New Hermes Vanguard 7200 with GravoStyle '98
    By tom12854 in forum Engraving Machines
    Last Post: 06-09-2015, 01:40 AM
  3. Help sending jobs with easy DNC to a Nisshinbo HTP 650
    By benjhouge in forum Controller & Computer Solutions
    Last Post: 04-16-2015, 03:08 PM
  4. Jobs!! Jobs!! Springville NY Jobs!! Jobs!! Jobs!! Jobs!!
    By HBP in forum Employment Opportunity
    Last Post: 11-15-2007, 04:41 PM
