586,075 active members*
4,182 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD Huayang EER.N error code
    Dec 2020
    Model HY02D211B 110v driving 2.2KW spindle
    Error Codes:
    177 ELU.N
    178 EER.N
    179 EER.N
    180 EER.N
    Manual lists as "External Interference".
    Any suggestions will be appreciated.
    Question:
    Any suggestions?
    Does the error code reset on restart?
    Perhaps I have to change the 110v AC supply cable to a shielded cable?
    Other:
    The spindle drive cable is 2 feet and is 16 gauge, 4 conductor, shielded with both ends grounded.
    I also grounded pin 4 of the spindle drive to the spindle body and checked continuity to table ground and input power ground.
    I tried setting PD041 from default 8 to 5,2,1, and finally 0 with no effect.
    The error code appears without ever starting the spindle.
    I used this and other helpful links to set the VFD settings and wiring:
    https://www.hobbytronics.co.za/Conte...e_Settings.pdf
    Ref: https://community.carbide3d.com/t/vf...-model/15459/7
    https://www.cnczone.com/forums/spind...rror-eoca.html
    Nov 2012
    1267
    Re: VFD Huayang EER.N error code
    Edit: Never mind, I was thinking of a different error code.
  1. 2.2kw spindle and Huayang VFD
    By tkms002 in forum Spindles / VFD
    Last Post: 02-08-2019, 07:15 PM
  2. Huayang VFD GT series Auto tuning
    By landy in forum Spindles / VFD
    Last Post: 02-03-2019, 08:47 PM
  3. Huayang VFD Hidden Commands
    By squirrel_41 in forum Spindles / VFD
    Last Post: 09-09-2017, 06:19 AM
  4. VFD Error Code
    By economycar in forum Phase Converters
    Last Post: 07-28-2017, 03:43 PM
