586,062 active members*
4,648 visitors online*
Results 1 to 11 of 11
    Mar 2017
    926
    Reversing axis direction in linuxcnc
    Please can someone tell me the best way to reverse the direction of an axis in Linuxcnc?
    I just realized that I accidentally built a dyslexic machine when my engraved letters came out backwards on the X axis...
    I read something about making it negative in Hal but I can't see which line needs to be changed.
    Jun 2007
    61
    Re: Reversing axis direction in linuxcnc
    Did you use stepconf or pncconfig to set it up? If so then check the box to reverse the axis. If you did a manual install then change the sign of the output_scale in the .ini file.
    Ed.
    Mar 2017
    926
    Quote Originally Posted by atex57 View Post
    Ed.
    I initial set it up using stepconf but I was hoping to change it without going through the whole set-up again.
    When you say change the sign of the output scale, do you mean making the limit a negative number?
    E.g. Is my X axis home is 0 and limit is 800mm, would I change the limit to -800mm?
    Jun 2007
    61
    My mistake, you are looking for input_scale=xxxx in your ini file. Change the xxxx to -xxxx, xxxx being your step count. I have never used stepconf but pncconf lets you page through if you select modify an existing setup. Play around with it, you can always cancel any changes at the end.
    Ed.
    Aug 2009
    1573
    ...reverse the wiring to axis motor/tach? or possible plan B what type axis drive are you using...it may have an Invert jumper/parameter setting on the PCB
    Mar 2017
    926
    Quote Originally Posted by machinehop5 View Post
    I'm using stepper motors via a Geck G540. There are no axis direction switches on the hardware (at least not that I can see on the outside).
    Is there an advantage to reversing the wires on the motors instead of adding a "-" in the INI?
    As mentioned , go to the ini file in configs and change the " scale " from either positive or negative .
    Aug 2009
    1573
    Quote Originally Posted by Goemon View Post
    ...depends on why the machine axis/joint is running backwards from normal. The next time you or someone changes CNC controller do not have to remember "Oh, I forgot that one of the axis is backwards"
    my two cents,
    DJ
    Jan 2018
    1516
    my two cents,
    DJ
    Yeah. Normally depends on wether you fit the motor on the left or right of the X table.
    If I remermber correctly you can swap the wires from A+A- to B+B- and the B+B- to A+A- and that will switch the motor direction.
    It's easier in Mach.
    You can go into soft limits page and just check the 'reversed' box and job done.
    I've also (accidentally) changed axis from 'active low' to 'active high' once, and the direction changed.
    Mar 2017
    926
    I finally got around to correcting my axis direction. As an FYI to anyone else looking to do this, it's in the HAL file, not the INI.
    May 2015
    686
    That does not really sound right but the ini file values are used in hal.
    In your ini file, for a particular joint I have
    Code:
    STEP_SCALE = 261.130715645
    If I wanted to reverse direction, I would use
    Code:
    STEP_SCALE = -261.130715645
    This value is steps per device unit (mm for me, you may be using inches). In Mach I think they call it Steps Per
    Rod Webster
    www.vehiclemods.net.au
  1. Intermittent issue with axis reversing direction after Homing
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2013, 01:53 AM
  2. Reversing Z direction in program
    By Janos in forum FeatureCAM CAD/CAM
    Last Post: 04-01-2013, 01:12 PM
  3. Reversing direction control
    By HLC_Fiesta in forum Techno CNC
    Last Post: 03-06-2010, 04:16 PM
  4. reversing homing direction without inverting axis?
    By draughted in forum LinuxCNC (formerly EMC2)
    Last Post: 04-08-2009, 10:04 AM
  5. reversing display direction
    By barnesy in forum Mach Mill
    Last Post: 12-18-2008, 04:47 AM
