Which drivers are you using, are they separate drivers for each motor and do they have Enable input. if possible, make a picture of the driver
If yes they have Enable, is anything connected to the enable ( check voltage between En+ and En- )
If there is no voltage, supply 5v between En+ and En - power up and verify is the motor is holding position.
24V should at least be enough for the driver to hold position rather strong .
