586,055 active members*
4,483 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Converting Parts List To Cad File!
    Apr 2021
    Hello Everyone!
    I Need a Software or Solution to convert an excel file or list To a vector file like DWG
    I Used a Nesting Program to import a CSV file , then exported the nested sheet to DXF file
    Is there any better options to give a bunch of Parts size and it give you a DXF or any other CAD file with the parts converted to rectangles in it
    Thanks!
    Jun 2015
    4154
    Re: Converting Parts List To Cad File!
    hy please share *.xls or list
    if you use a nesting program to convert csv to dxf, then why do you need another alternative ?
    why do you need the final dxf/dwg/cad ? what is the purpose of your final file ?
    youtube : solidworks import excel table / kindly
    Mar 2009
    1982
    It's easy to get point cloud. Point cloud is easy to convert to STL and so on. The method used to sculpture irregular shapes - to import artpieces or human head 3D pictures to CAD. If the shape is regular, then it's even easier.
    I think there's a gadget that works with V Carve Pro and Aspire that will give this capability?
    A more poerful (and much more expensive) option is CadCode. https://www.cadcode.com/
  1. cnc mini lathe parts list and cad models
    By andyf97 in forum CNC "do-it-yourself"
    Last Post: 01-31-2021, 08:30 PM
  2. Replies: 3
    Last Post: 11-13-2020, 06:14 PM
  3. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  4. using a data file for both 3D printer and CNC router , Converting file or ???
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 12-17-2014, 01:32 AM
  5. Converting turbo cad into a dfx file
    By Moroni in forum Uncategorised CAM Discussion
    Last Post: 02-12-2013, 05:36 PM
