587,076 active members*
3,430 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > 3d SCANNERS for reverse engineering parts ?
Results 1 to 6 of 6
    Oct 2018
    101
    can you guys recommend a good 3D scanner? does anybody use the desktop versions?
    Oct 2018
    101
    Re: 3d SCANNERS for reverse engineering parts ?
    nobody has got one ? ?Nextengine 3D ? EinScan Pro HD?
    Aug 2005
    205
    My office hand a NextEngine scanner for doing small organic objects. We weren't looking for precise meshes. Just something to get us close. It worked well for that. Still it was 4 grand back in 2014.
    Depending on your needs, I would look at software that uses your phone. There is some pretty remarkable stuff happening there.
    Apr 2008
    91
    Try: https://3dunderworld.org/ for a free software solution.
    You can also get an HP sls 3d scanner pretty inexpensively compared to other options. Unlike other options, the camera and projector are seperate, thus you can repair it cheaply if somethine fails. I avoided Einscan because earlier on they had quality issues out of warranty and I don't think they offered repair services back then.
    I got the HP just so that I can always have something that works. It works very good but you have to manually move the piece and make each scan seperate. There is a DIY solution for a turn table, I'd try and go that route. The official turn table price is through the roof.
    Jul 2018
    6452
    Hi Okuma - You need to describe what you want to do or need to do. You can spend $200 or $2M on a scanner. Peter
    Apr 2008
    91
    BTW if you get a typical HP 3d scanner, you can get accuracy of Up to 0.05% of scan size. That's pretty good. For reflective surfaces you need to apply a dulling spray or developer spray works. They make special 3d scan spray too.
    When scanning very precise features you actually need to account for the added thickness due to the spray.
    If you only want to scan parts you can use just about any 3d scanner.
    To do real reverse engineering you also need a suitable software.
    Geomagic Design X costs 20K for a perpetual liscense. They offer a cheaper software creaform or something for 5k.
    Solidworks can do a lot of functions you will need with an add in, scan2 3d I think. Maybe scan 2 cad.
    Inventor had an add in that worked until the latest version, not sure if the add in has been updated yet.
    So yeah you need more than just the scanner for reverse engineering.
    Unless there's a scanner out there that unbeknownst to me comes with some reverse engineering software.
  1. Replies: 1
    Last Post: 03-18-2021, 06:38 PM
  2. Reverse engineering NC file
    By Ghii in forum Post Processor Files
    Last Post: 06-10-2011, 02:13 PM
  3. Reverse Engineering
    By plasmator in forum MetalWork Discussion
    Last Post: 08-25-2010, 10:21 AM
  4. Help with reverse engineering
    By randycasey in forum Solidworks
    Last Post: 10-06-2008, 11:56 PM
  5. Reverse engineering
    By quadbob in forum PTC Pro/Manufacture
    Last Post: 04-27-2007, 12:54 PM
