586,100 active members*
3,096 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > The control pins of the stepper motor driver of A3977
Results 1 to 2 of 2
    Mar 2016
    4
    The attached pictures shown a stepper motor driver of A3977 driver from an old mini CNC machine, which used 5 pins for the control.
    Need help on the pinout of this board, for repair or replacement.
    Adam
    https://www.cnczone.com/forums/attac...d=462546&stc=1https://www.cnczone.com/forums/attac...d=462548&stc=1
    Dec 2012
    199
    Re: The control pins of the stepper motor driver of A3977
    For the control connection.
    The left pin ( closest to the center of the board of you first picture ) is the +5V connection for all three inputs
    the next one is CLK or PULL ( active low )
    the third one is DIR ( active low )
    For the ENable ( active low ) I am not sure if it's connected to pin four or pin 5. It looks to me pin 5 You can check that with a ohm meter between the pin and the hole just above.
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. control stepper motor driver controller L297 using Pic ????
    By watzmann in forum CNC Machine Related Electronics
    Last Post: 04-12-2012, 11:09 PM
  3. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  4. Need help to locate stepper motor control board plus driver
    By Techbuilder in forum Stepper Motors / Drives
    Last Post: 10-17-2008, 02:53 AM
  5. Need help to locate stepper motor control board plus driver
    By Techbuilder in forum DeskCNC Controller Board
    Last Post: 10-14-2008, 01:11 PM
