Hello All,
I may have hinted towards it several months ago. I have bought an ES-L6 lathe with U10L control. I bought the machine to make some extra money on the side in an attempt to pad the bank account some. I put basically everything I had saved back into it. I struggled with the decision for a few days before I went ahead with it.
Just in the last two weeks I have been able to work on it. It's been an adventure I'll say but I don't want to waste time here with the whole story. Well, we can say my fears are beginning to show theirs heads.
I am running the machine on a 20HP rotary phase convertor. I got the machine up and running, everything moved as it should spindle real smooth, X/Z axis moved great. I snapped some pictures of the control cabinet as everything running correctly for future reference. Turned out the future was closer than I had anticipated. I was running a dummy program left in the machine from the previous owner with no stock in the machine just to test that everything would function as I expected. Then at the end of the program maybe even the rapid to home position it stopped with an X axis alarm. This time I wasn't smart enough to snap a pic. I restarted the machine and it didn't finish booting up when it throws Alarm P 0812. Going through manuals leads me to the X axis drive or MIV unit. MIV unit is giving error EL 02. Manual says replace MIV. One other noteworthy point is that the previous owner replaced I believe the DC power supply.
At this point I can't sink much more money into it. I just don't have it right now. I'm fairly crafty and could attempt a repair.
That's the back story, so here is the questions. Say I get this fixed, is this going to be an on going issue of components failing because I am on a phase converter? Has anyone else attempted and succeeded at a repair? Could the problem be just a bad/leaky CAP or IGBT that can be swapped out easy? Fortunately I am not under any deadlines so I am not worried about how long it takes or letting anyone down.
Any thoughts are welcome.
Thank You all,
Dave in Ohio
