586,047 active members*
3,883 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > High efficiency auto tool changer wood design cnc router machine for furniture proces
Results 1 to 1 of 1
    Jul 2020
    3
    The processing size of AKM1325C is 1300mm×2500mm.The table top is a Vacuum table, which is fixed on the table by vacuum adsorption and gas suction, which is more stable and saves a lot of time. At the same time, it is equipped with 5.5KW air pump double stage for supporting use.The standard configuration of this engraving machine is a 9.0KW HQD air cooling automatic tool change spindle with 8pcs of fixed linear tool changer. If you need to use different cutter heads for engraving, this automatic tool changer is very convenient, it can greatly improve your processing efficiency, save a lot of time, and is very suitable for complex and large-scale engraving processing.The XY axis of the AKM1325C adopts gear transmission, and the Z axis adopts screw transmission. This engraving machine is equipped with Taiwan TBI ball screw. The guide rail is made of Taiwan Hiwin, which has high precision and stable operation, which makes the engraving more precise. The other feature of AKM1325C is that it uses an Auto oil lubrication, which automatically oils the guide rail and the lead screw. In addition, it is equipped with 3.0KW double bags dust collector, which can directly collect waste such as wood chips and dust into the dust bag when processing the board, making the working environment cleaner.
    Product Links:https://www.acctekgroup.com/ATC_CNC_...outer_105.html
    web:https://www.acctekgroup.com/index.html
