586,051 active members*
3,666 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 103
  1. #41
    Oct 2009
    733
    Re: David A's Benchtop CNC Version 2
    INSTALLATION OF FRONT BRACES:
    Parts for the front brace (one side):
    Attachment 464602
    Carefully move the gantry forward to the front edge of linear rails:
    Attachment 464604
    Area of the front braces to be installed:
Name:	Front Brace 3 color arrow.jpg
  2. #42
    Oct 2009
    733
    Cut off 14 pieces from the 3/8 backer rod, about 3/4" long each:
    Attachment 464616
    Slide in a T-nut and a backer rod piece. Push it up in the slot and slide in the next set:
Name:	Front Brace 5 color.jpg
    Position a total of 7 nuts with backer rods in the vertical slot per side.
    Roll in a total of 10 T-nuts into the horizontal slots.
    See photo:
    Attachment 464618
    Bring the front brace in place and slide the foam pieces to align the
    nuts with the brace holes in vertical slot. Slide also roll-in nuts to align:
    Attachment 464620
  3. #43
    Oct 2009
    733
    Hand-tighten front brace:
    Attachment 464622
    Install front cap and tighten everything down:
    Attachment 464624
    Attachment 464626
    From the back, glue two bumpers into recesses as done previously:
    Attachment 464628
    Attachment 464630
    Attachment 464632
    ASSEMBLY OF MACHINE FRAME IS FINISHED:
Name:	Front Brace 14.jpg
  4. #44
    Oct 2009
    733
    Machine frame assembly is finished. X-carriage / Z-slide assembly was finished before that:
    Attachment 464680
    Time to install the assembly onto the gantry.
    First, Z-slide assist springs need to be installed to prevent the Z-slide from crashing down onto the bed.
    Flip the assembly so that the spindle is in the back:
    Attachment 464682
    This is where the springs will be attached:
    Attachment 464684
    Four springs, two pins and a pull wire:
    Attachment 464686
    Place a block of wood about 2" thick between the slide and the top plate.
    I used a piece of 2x4:
    Attachment 464688
    Push the spindle up against the wood block:
    Attachment 464690
  5. #45
    Oct 2009
    733
    Insert two of the springs into the slot:
    Attachment 464694
    Run the pin through the loops and push into the seat and
    pull the other end of spring through the second slot with the pull wire:
    Attachment 464696
    And slip that spring end over the arm of spindle mount:
    Attachment 464698
    Do the same for the second spring:
    Attachment 464700
    Attach the other two springs the same way
    to the other arm of the spindle mount:
    Attachment 464702
    Spring assist from the back:
    Attachment 464704
    Spring assist from the front:
    Attachment 464706
  6. #46
    Oct 2009
    733
    IT IS HEAVY! YOU NEED ASSISTANCE!
    Take the whole X/Z assembly and slide over the gantry trucks:
    Attachment 464708
    First attach the upper plate to the trucks using 5mm screws and then the lower plate:
    Attachment 464710
    X-carriage with the Z-slide on the gantry:
    Attachment 464712
    https://youtu.be/v7fHg42MOUM
  7. #47
    Oct 2009
    733
    Before the cross brace in the back of the X-carriage and all the other
    periphery gets installed, it would be easiest to tram the Z-slide now.
    Make sure all the screws and set screws shown and the corresponding
    ones on the other side of the Z-slide are only finger-tight:
    Attachment 464802
    Put two 12" clamps top and bottom across the two side plates.
    Make sure they clear the set screws:
    Attachment 464804
    Tighten them a bit at a time while moving the Z-slide up
    and down until you can feel some drag on the Z-slide:
    Attachment 464806
    LEAVE THE CLAMPS IN PLACE !
  8. #48
    Jul 2018
    6339
    Hi David - what software are you using for your graphics? Peter
  9. #49
    Oct 2009
    733
    Install two #10 x 2-1/2 screws into the back side of the top plate (blue arrows).
    They and the four set screws on the side plates will be used for tramming:
    Attachment 464808
    Perform your preferred method of tramming. I found ProTram from Edge Technologies easy to use:
    Attachment 464810
    Attachment 464812
  10. #50
    Oct 2009
    733
    Hi Peter,
    It's not really graphics per say but simple image manipulation in Pixelmator Pro.
    And I think I'm pretty mediocre with that after seeing what other people can do.
  11. #51
    Oct 2009
    733
    The last three images somehow don't show up on my computer so I am re-posting here:
    Attachment 464816
    Attachment 464818
  12. #52
    Oct 2009
    733
    Tram first the RIGHT TO LEFT direction.
    In my case, it was close and needed just a bit of adjustment.
    LEFT TO RIGHT direction trammed, tighten down all four ball
    bushings in small and alternating steps to the upper and lower plates:
    Attachment 464822
    You can take off the clamps on the side plates now and tram FRONT TO BACK direction.
    FRONT TO BACK direction trammed, first tighten down upper and lower plates with 5mm screws to X-linear rail trucks:
    Attachment 464824
    Then tighten down the side plates to the ball bushings:
    Tramming is finished.
  13. #53
    Oct 2009
    733
    Install the back brace and the support support wing on the
    X-carriage to finalize the X-carriage / Z-axis slide installation:
    Attachment 464874
    Attachment 464876
    Use the set screws in the front of ball bushings to tighten the bushings
    until the slide moves with some resistance similar to linear rail trucks:
Name:	Tram 13 color arrows.jpg
  14. #54
    Oct 2009
    733
    THIS COMPLETES THE MECHANICAL ASSEMBLY OF THE MACHINE
    Next up will be the assembly of peripherals.
  15. #55
    Oct 2009
    733
    PERIPHERALS AND ADD-ONS FOR THE MACHINE
    CABLE MANAGEMENT:
    Cable management starting from the spindle side will be installed on the spindle clamp:
    Attachment 464934
    Install one 10-24 threaded rod on the spindle clamp.
    Use two locked coupling nuts to screw in the rod as far as it will go:
    Attachment 464936
    Install the same way the other threaded rod.
    Install the power connector for the spindle:
    Attachment 464938
    Tighten down the two threaded rods with the coupling nuts:
Name:	Cables 4 color.jpg
  16. #56
    Oct 2009
    733
    Slide down the red plastic part behind the two threaded rods as shown.
    There is space on the red plastic for an electrical auxiliary connection if you want to use that:
    Attachment 464942
    Screw on the front plate onto the red plastic part using the lower four holes:
    Attachment 464944
    Take the back plate:
    Attachment 464946
    Place it behind the red plastic part:
    Attachment 464948
    Finish installation by tightening the back plate using the upper six holes:
Name:	Cables 9 color.jpg
  17. #57
    Oct 2009
    733
    Install the 15-segment drag chain to front assembly:
    Attachment 464994
    Attach the other end to the cross brace in the back:
Name:	Cables 11 color arrows.jpg
    Upper drag chain is installed:
  18. #58
    Oct 2009
    733
    Shelf for the long gantry drag chain in the back comes assembled:
    Attachment 465028
    Attachment 465030
    Hook onto the top channel and push down. It snaps in place:
    Attachment 465032
    Install long drag chain onto the shelf:
  19. #59
    Oct 2009
    733
    The Z-axis and X-axis drag chains are installed.
    Front junction box was installed previously.
    Gantry junction box is next:
    Attachment 465156
    Parts of gantry junction box:
    Attachment 465158
    Install as shown and pull all wiring through the cap.
    Push excessive lengths of cables into cavities.
    All aluminum edges are covered by plastic cap:
    Attachment 465160
  20. #60
    Oct 2009
    733
    Gantry junction box installed.
    Install the second end cap onto the other end of gantry:
    Attachment 465162
    Install drag chain bracket (green).
    Hook on pre-assembled drag chain shelf into extrusion channel (blue):
    Attachment 465164
    Install drag chain:
    Attachment 465166
    Cable management from electrical box to the spindle is finished:
Page 3 of 6 12345
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
