586,058 active members*
3,320 visitors online*
Page 1 of 6 123
Results 1 to 20 of 103
    Oct 2009
    733
    David A's Benchtop CNC Version 2
    Hello all,
    Some of you might remember, I had posted a thread called "David A's New 2x3 Benchtop CNC" about two years ago.
    https://www.cnczone.com/forums/diy-c...h-top-cnc.html
    The machine has been running good and received quite a bit of changes in those two years so I thought I start a new thread showing the improvements I made since then.
    Oct 2009
    733
    Re: David A's Benchtop CNC Version 2
    First, I built a double-walled base out of Birch ply with 4x4 posts at each corner. Bottoms of these
    pockets are closed in case I want to mass-load it with sand:
    Attachment 462892
Name:	Table Naked.jpg
    Oct 2009
    733
    It takes 2-1/2 sheets of 4x8 ply and about ten feet of 4x4 post.
    For anybody who might want to build something similar, each image is one sheet:
    Attachment 462896
    Oct 2009
    733
    I plan to build these machines in 2x2, 2x3 and 2x4 sizes and make them available for purchase.
    Therefore, I will progress with the thread like a customer had just received his/her order.
    The sample desktop shown here is the 2x3 desktop.
    Oct 2009
    733
    The machine will arrive in a reusable birch ply crate:
    Attachment 463088
    With panel markings for re-assembly:
    Attachment 463090
    The crate is disassembled/reassembled with industry standard steel clamps:
Name:	Crate Spring.jpg
    Oct 2009
    733
    The crate contains the fully assembled, bolted, bonded and watertight machine frame.
    (Padding and strapping removed):
    Mar 2018
    68
    Nice Keep Up!
    Oct 2009
    733
    Thank you Hugues.
    The naked frame weighs about 170 lbs.:
    Attachment 463170
    All mounting surfaces for linear rails on the machine are machined:
    Attachment 463172
    Attachment 463174
    Oct 2009
    733
    All other assemblies of the machine are mounted on the bottom plate of the crate, underneath of the machine frame.
    (Padding, strapping and small parts boxes removed):
    Attachment 463218
    Major assemblies:
Name:	Assemblies 1 arrows.jpg
    Oct 2009
    733
    I wanted to fill the base with sand as it would be difficult to access the pockets after the top and the machine is put on the base. Couldn't find any sand which was dry. All the bags were somewhat moist. So I filled the base with 400 pounds of moist sand.
    Letting the sand dry in the pockets before proceeding:
    Oct 2009
    733
    Amazing how long it takes to dry out the sand all the way to the bottom, even with a large fan blowing over it.
    While I wait for that, I will start with the assembly of some components.
    Oct 2009
    733
    X-Carriage and Z-Slide assembly:
    Main components of the X-Carriage and the Z-slide:
    Oct 2009
    733
Name:	X_Z 1 arrows.jpg
    Oct 2009
    733
    Z-slide by itself:
Name:	Z 1 arrows.jpg
    Oct 2009
    733
    If you are planning on using a water cooled spindle, now is a good time to install the cooling hoses.
    I use 1/4"ID-3/8OD hoses from McMaster. Quite a bit sturdier and pliable compared to big box store
    material and stays better on most nipples without additional clamps.
    Attach two 3' hoses to the spindle. It is a bit tight but it will fit:
Name:	Spindle hoses.jpg
    Oct 2009
    733
    Place the spindle into the spindle mount.
    Make sure that the nipples are inline with the shafts:
Name:	Spindle mount 1 arrows.jpg
    The transition of the bottom bearing holder to the spindle body should just daylight from the mount:
Name:	Spindle mount 2.jpg
    Oct 2009
    733
    To start assembling the X-carriage, slide the 30mm ball bushings of
    the bottom plate from the bottom over the Z-slide shafts.
    Make sure that the pockets on the plate are at the bottom:
Name:	X Assembly 1.jpg
    Remove the top clamp of the Z-slide and push from the top the
    upper plate ball bushings onto the Z-slide shafts.
    Make sure that the four aluminum spacers are on top:
Name:	X Assembly 2.jpg
    It should look like this:
Name:	X Assembly 3.jpg
    Oct 2009
    733
    Now take off the 8mm screws on the 30mm ball bushings
    on both the upper and lower plates:
Name:	X Assembly 4.jpg
    And install the side plates on sides.
    Leave everything just hand tight for now:
Name:	X Assembly 5.jpg
    The rough assembly of the X-carriage and the Z-slide is
    finished and ready to be mounted onto the gantry:
Name:	X Assembly 6.jpg
    Oct 2009
    733
    A short demonstration of the Z-slide:
    https://youtu.be/hAQXOgrQAss
    Oct 2009
    733
    Comments, suggestions, dislikes/likes very welcome.....
Page 1 of 6 123
  1. David Rigotti - Hobby CNC Plans
    By KeithSloan in forum DIY CNC Router Table Machines
    Last Post: 03-30-2020, 01:51 PM
  2. David A's New 2x3 Bench Top CNC
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 08-18-2019, 01:47 AM
  3. Replies: 1
    Last Post: 03-29-2017, 03:18 PM
  4. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
  5. I built My CNC From David Steels Plans Now I need Feedrate help please
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 09-09-2007, 07:52 PM
