586,058 active members*
4,626 visitors online*
Results 1 to 5 of 5
    Longmill vs DIY?
    Hey y'all, so I was planning on building my own CNC, approx. 2ft x 2ft x 4in work area and with a budget of ~$1500. I was aiming for wood/plastics primarily, but would love aluminum capabilities. However, I just discovered the Longmill CNC which is 30 in x 30 in x 4 work area and all in all it'll cost a little under $1500. Is it worth it for me to build? I'm not intimidated by the design/construction process and I have access to woodworking and metalworking machinery, I just want to make sure my efforts will be not wasted. Thanks for the help y'all
    Nov 2007
    483
    Re: Longmill vs DIY?
    If I had to go with 8mm leadscrew and delrin wheels I'd just buy a openbuilds clone from the east. I'd be much more inclined to build a printnc but a 3d printer is required.
    I do have a 3D printer available, but do you think I could build a more robust machine for $1500?
    Nov 2007
    483
    More robust than the delrin wheel versions of cnc? Yes. Those wheels are not known for longevity under load. I definitely think you could make a much more rigid 2'x2' frame for less than $1500 but you would have to figure out the design yourself. A kit is not a bad way to start but you do get what you pay for. I would look at youtube video's on printnc to give you some idea what is involved in a first time steel tubing diy build.
    I'm honestly not all that intimidated by the design part (maybe I should be lol). But I definitely get what you're saying, thanks for the advise.
  1. DIY drag engraver for my DIY CNC
    By A_Camera in forum Engraving Machines
    Last Post: 04-01-2021, 07:16 PM
  2. Using my upgraded DIY CNC and DIY pen holder (video)
    By A_Camera in forum DIY CNC Router Table Machines
    Last Post: 03-31-2016, 09:28 AM
  3. Anybody find a good Chinese 4th? Or go DIY? (Q's on DIY)
    By Zeppelin1007 in forum Wood Lathes / Mills
    Last Post: 11-24-2014, 09:47 PM
  4. DIY vinyl cutter for DIY MDF router table!
    By PropNut in forum DIY CNC Router Table Machines
    Last Post: 09-10-2010, 03:25 PM
  5. DIY Mister for DIY CNC Router?
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 07-07-2009, 06:34 PM
