586,076 active members*
3,963 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Jun 2017
    119
    Re: Planet CNC THC.
    Quote Originally Posted by PlanetCNC View Post
    Sdt - Set delay time from 0.1 to 9.9 sec. Time between Arc OK signal appears and generation of signals up and down is enabled. Factory setting 0.5 s.
    HYS - Hysteresis from 2V to 32V (2 V step). Voltage frame around reference. If arc voltage is higher than Ref + HYS/2 then down signal is generated. If voltage is lower than Ref - HYS/2, up signal is generated. Factory setting 6 V.
    AdL - Ant-dive limit from 50V to 300V. Arc voltage that disables THC. If voltage goes higher than Anti-dive limit all output signals go low. The parameter’s value must be set higher than reference voltage. Factory setting 220V.
    tSt - Test mode. Only available when no arc voltage present! Pressing V or ? button generate output signals. The display indicates direction.
    tSt - Test mode. Only available when no arc voltage present! Pressing V or ? buttongenerate output signals. The display indicates direction.
    So when you use this Test Mode. Should you get a input signal on TNG Up/down input to where you connected your wires?
  2. #22
    Jun 2017
    119
    Re: Planet CNC THC.
    Quote Originally Posted by MrEmo View Post
    Yes/No?
    The reason I am asking is that I am not getting these signals when I run this mode and push up and down.
  3. #23
    Jun 2017
    119
    Re: Planet CNC THC.
    Yes/No?
    Hello?
    I am trying to tell you that your THC is not working as it should. It is not sending up or down signal in test mode and I am not receiving signals in the software...
  4. #24
    Mar 2017
    1312
    Re: Planet CNC THC.
    In test mode, when you press button, what does THC display show?
  5. #25
    Jun 2017
    119
    Re: Planet CNC THC.
    See attached photos.
  6. #26
    Mar 2017
    1312
    Re: Planet CNC THC.
    This is ok. How is controller connected to thc?
  7. #27
    Jun 2017
    119
    Re: Planet CNC THC.
    50:1.
    I get voltage on the thc when machine running.
    But I am not getting signals on software on the inputs that are designated. Nothing is showing up on I/O thingy.
  8. #28
    Mar 2017
    1312
    Re: Planet CNC THC.
    On your photos all wires are black. I want to know how THC is connected to controller.
  9. #29
    Jun 2017
    119
    Re: Planet CNC THC.
    I swapped some wires around. I have tried several ways to connect the Common wire and I went back to one of the first ways I connected it and now it decided to work.
    But fear not, I am not done yet.
    I have a new problem.
    I am now back to having ARC OK signal on input 7. The machine starts cutting but then it suddenly stops. I am unable to restart the machine within the software. Nothing is working, start, stop, pause, emergency stop does nothing.
    Try to reboot software still not able to start machine.
    If I remove ARC OK from settings I am able to proceed or I have to reboot hardware.
    So this has something to do with ARC OK must be something in the software?
Page 2 of 2 12
  1. Planet CNC as PNP
    By sairfan1 in forum PlanetCNC
    Last Post: 04-15-2021, 06:04 PM
  2. Replies: 1
    Last Post: 03-07-2021, 11:42 PM
  3. Replies: 1
    Last Post: 11-10-2018, 02:26 AM
  4. Planet CNC without THC Option
    By phamandp in forum PlanetCNC
    Last Post: 08-31-2018, 02:42 PM
  5. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
