586,106 active members*
3,062 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Lost license on 6040 and PlanetCNC control
    Nov 2020
    16
    My CNC was working well, until today. I messed up on a few lines of Gcode and failed to set the Z axis to zero and when I clicked play, the spindle plunged down jamming into the jig I had holding my work. Before I could hit the E stop, the fuse popped. I replaced the fuse and I couldn't reconnect the laptop to the controller. I swapped USB cables and still no dice. I tried restarting everything, that didn't work either. I dug a little deeper and it looks like my license isn't valid. I tried to reactivate the software with the controller and it's giving me an error. What am I missing? I'm sure it's something simple and I'll kick myself. But I need this machine running ASAP
    Thanks.
    Mar 2017
    1312
    Re: Lost license on 6040 and PlanetCNC control
    Controller should work (with limitations) even without license.
    Nov 2020
    16
    Quote Originally Posted by PlanetCNC View Post
    It doesn't connect at all. I tried a different cable with the same results, even tried a different laptop. Is it possible the controller is shot? If so, I'll order a new one right away. I don't think I've had this for a year. I'll have to verify which one I need. When I get a chance I'll take a picture and post it.
    Nov 2020
    16
    This is what I have right now. This is what I assume I need, https://planet-cnc.com/product/mk3-drv/
  1. Issues with spindle on 6040 and PlanetCNC control
    By XRing3 in forum Drilling- and Milling Machines
    Last Post: 11-02-2020, 10:26 PM
  2. Script commands to control PlanetCNC
    By Cruzes in forum PlanetCNC
    Last Post: 08-23-2019, 09:25 PM
  3. Is the PlanetCNC software license transferable?
    By retrosmith in forum PlanetCNC
    Last Post: 01-23-2019, 02:25 AM
  4. Closed loop control in PlanetCNC
    By ccandiotes in forum PlanetCNC
    Last Post: 09-24-2017, 12:04 PM
  5. Lost my License
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 10-10-2008, 10:27 PM
