586,089 active members*
3,933 visitors online*
    May 2004
    34
    X axis vibration
    I have a Bridgeport sers. 1 with a Crusader 2 control. It uses SEM brush type servos with Glentek servo drivers and glass scales for position. The problem is that the X axis vibrates and gets VERY HOT when stopped. I have set the signal and balance as per Anilam instructions and it is a bit better but if you place a load on the hand wheel it will start vibrating and then wont stop. Swapping the drive cards or servo motor the problem stays with the X axis. Removing the feed back conections no difference. The Y and Z axis are fine they make the normal "singing" noise when stopped. Anyone have any ideas were to look next?
    thanks Bill
    24221
    Usually the gain setting too high.
    Al.
    Albert E.
  1. cause of Z axis vibration
    By dahui in forum Shopmaster/Shoptask
    Last Post: 08-17-2007, 03:39 AM
  2. Too much vibration with my X2.
    By alexccmeister in forum Benchtop Machines
    Last Post: 06-04-2007, 07:36 PM
  3. Extreme Vibration with FNC
    By 1ctoolfool in forum Haas Mills
    Last Post: 12-05-2006, 04:37 AM
  4. Vibration in X axis of lathe
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 05-19-2006, 08:57 PM
  5. vibration / resonance
    By boyvox in forum DIY CNC Router Table Machines
    Last Post: 04-11-2006, 05:33 PM
