586,069 active members*
3,592 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Tiling with Fusion360
Results 1 to 6 of 6
    Question Tiling with Fusion360
    I have a piece to cut larger than my table so I setup to "tile" cut with two operations. I'm using a 2D contour operation setup for three even step downs on my DIY CNC router.
Name:	Tile Sheet.jpg
    The problem is the 8 deg. ramp down seems to be ignored. Or the cut is doubling back all the way to the beginning of the cut as if to cut in one direction only. Either way it is doubling the time to cut and adding ware to the tool.
    Attachment 463164
    I selected "cut both ways" and there is no difference.
    The odd thing is for smaller pieces completely within the stock contaminant ramp properly.
    Attachment 463166
    Something about the contaminant boundary seems to mess up the ramp. All the online example are using a single pass cut. I can't with my DIY machine.
    Any ideas how to fix the ramp issue?
    Dec 2013
    5717
    Re: Tiling with Fusion360
    Try Zig-Zag ramp and see what happens.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2014
    724
    Can you post the f3d file? You may need to zip it first before posting.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Unhappy Re: Tiling with Fusion360
    Quote Originally Posted by difalkner View Post
    The attached F360 file is just one example.
    Dec 2013
    5717
    OK, I fixed it See Setup1>Contour 1 (5), (7), (6) I suppressed the other opps in that setup for clarity. Made 3 operations. Needed to do that because of the open contour due to the constraints. Obviously Fusion doesn't handle this well, but that's the work around.
    Attached Files Attached Files
    Jim Dawson
    Sandy, Oregon, USA
    Jim, I see how you you did that. Thank-you this will come in handy now and down the road.
  1. Fusion360 post
    By yugami in forum Milltronics
    Last Post: 04-15-2019, 09:36 AM
  2. Rotary around Z fusion360
    By dbunyip in forum Tormach Personal CNC Mill
    Last Post: 01-04-2018, 12:41 PM
  3. Tiling for larger jobs
    By al010964 in forum Tormach Personal CNC Mill
    Last Post: 08-27-2017, 02:24 AM
  4. Tiling large signs?
    By fatal-exception in forum Vectric
    Last Post: 02-26-2012, 05:47 PM
  5. Copying multiple objects / Tiling Help
    By viroy in forum Solidworks
    Last Post: 06-28-2011, 01:02 PM
