586,080 active members*
3,614 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Machining Centres > 5 Axis CNC- toolpath not working right
    May 2021
    I have generated a 5-axis toolpath for a simple model using Powermill 2020. After I export the g-code and load it onto the machine, it does not work properly. The exact issue is that the machine is not milling according to the material block. It is going outside the block and the coordinates do not match the simulation in Powermill.
    When I export the code, Powermill shows me an error saying “ the machine tool in Powermill and the machine tool in option file differ “. Can this be the issue for the coordinates not exporting properly?
    Attached Thumbnails Attached Thumbnails 5 axis CNC_ Setup.jpg   Control software settings.jpg   export error_Powermill.jpg
    1227
    Re: 5 Axis CNC- toolpath not working right
    Almost certain to be the problem.I don't know Powermill,but if the default machine geometry that the program comes with doesn't match the machine you are using,it will be unlikely that the toopathyou generate will produce the shape that has been designed.There may well be a couple of places in the postprocessor parameters where you need to insert the values relating to your machine.Almost certainly related to either the tool length or the distance from the tool tip to the centre(s) of rotation.
