586,071 active members*
3,704 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc drill mate option parameters
Results 1 to 14 of 14
    Sep 2019
    14
    I have a 1991 Fanuc drill mate model c with o-m controller. It recently had its memory scrambled. I had a 417, 427, and 437 digital servo parameter alarms. I was able to get a copy of the control parameters but Fanuc said I needed to call the tool builder for the option parameters. I called methods and they told me they did not build this machine and they don't know who did. The only suggest they could offer me was find someone who has the same machine and see if they would email you a copy of there option parameters. If anyone has one of these machines could you please contact me. Thanks everyone for all the great information supplied in this forum! It has helped out more times than I can count!
    Dec 2009
    953
    Re: Fanuc drill mate option parameters
    do you have a photo of the serial number of the machine and also the serial number above the motherboard?
    do you any paper ,aka "data sheet"?
    Sep 2019
    14
    Picture of the plate
    Sep 2019
    14
    Picture of motherbboard
    Sep 2019
    14
    I bought the machine used and it came with the manuals but no data sheets.
    Apr 2006
    111
    Your master pcb is not for Fanuc 0-mate. it is rebuilded. my machine master ocb is in picture
    Attachment 463486.
    Sep 2019
    14
    Wow now I'm really not sure what to do????
    Apr 2006
    111
    Quote Originally Posted by Bethk View Post
    This is what I think. Original your machine use master pcb same as my machine. But your machine is rebuild with other master pcb so you should find rebuilder
    Sep 2019
    14
    Could you please send me a copy of your option parameters? I tried getting in touch with Fanuc and methods and neither could help me. I don't know who to call next?? If I had a list and my book maybe I can get it running. My email is [email protected]. Thank you for all the info.
    Dec 2009
    953
    can you have a more good quality photo?
    or can you write down the :Serial number with P922.......
    Sep 2019
    14
    The first plate says
    Type A04B 0073 A001
    The serial number is P922CA096
    I also have another plate on the other cabinet door that says
    Type A04B-0073-B201
    Serial no. 1084371
    I think one is for the machine and one is for the control?? Not sure tho?
    Apr 2006
    111
    You check email
    Dec 2009
    953
    this will be very complicated for you
    this mother board is from a double spindle lathe
    A20B-2000-0180 PCB - MASTER B FS-0TTC 32 BIT
    you will have hard times to put it back as the most important is the diagnose parameters that can be rebuild from ladder sequence but you need a good guy
    Nov 2007
    352
    1991 What model of a machine is this ?--------------2 Axis lathe or Mill ?------------What control a OM or OT ?
    Does the machine power up to IPL screen ?-----------Does it have any functions at all ?---------Pictures of the control powered on ?----------------------If a OT or OM you only need 900 to 923 as these are options for the machine and changes the control alot if not correct
  1. Replies: 1
    Last Post: 01-12-2016, 07:06 PM
  2. help with Fanuc tape drill mate
    By landslide1 in forum Fanuc
    Last Post: 11-10-2012, 01:46 AM
  3. Fanuc OM option parameters
    By allmetalcnc in forum Fanuc
    Last Post: 06-19-2008, 02:31 PM
  4. anyone have a Fanuc drill mate or robo drill?
    By goodplastics in forum G-Code Programing
    Last Post: 07-22-2007, 04:36 PM
