Hi there. I have a CHURCILL HC/10 1987 SISTEM FANUC 10T lathe and something is not working properly, because i can't get it started. I worked with it before and it worked great, but suddently it doesn't work anymore. First i thought that the motor was broken and i sent it to be fixed...but after setting the motor back, the problem persists. What happenes is that the fuses fails when turning on the machine. Two of three fuses always fail when turning on the machine (but NOT the same two..they fail kinda' randomely, but allways two of them fail). I called for some electricians to have a look at it but they couldn't find the problem. It's been an year since it stoped working and since then i had to decline a lot of orders 'cause i can't work with it anymore, and it's my only CNC lathe. If anyone has an ideea about what the problem could be, can you, please, help me? Thanks.
