586,119 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Z axis cuts too deep
    I’ve got a Fadal VMC 40, using a calmotion usb, and fusion 360:
    So x and y axis all run true to the cam programming. However the z axis alway cuts too deep/runs into the part to aggressively to get there. I have done tool setting and fixture setting 100x and don’t know what I’m doing wrong. It tends to cut in nearly 1/2” too deep every time. This machine is new to me, and I am new to machining. I feel like I’ve been through every manual and website trying to find what I’m missing and can’t find it. Any suggestions?
    Dec 2013
    5717
    Re: Z axis cuts too deep
    Are you setting the Z zero in the same place both in Fusion and the part? I normally Z set to the top of the part. Sometimes Fusion can be a little tricky to setup properly, you have to make sure it did what you expected. Simulation is your friend.
    Jim Dawson
    Sandy, Oregon, USA
  1. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  2. Z axis going too deep
    By haz_kiev in forum Mach Software (ArtSoft software)
    Last Post: 09-26-2013, 02:58 PM
  3. X axis keeps cutting out during cuts.
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 09-27-2011, 04:20 PM
  4. *Scared* Deep Cuts
    By Cosha in forum CNC Tooling
    Last Post: 07-02-2011, 05:09 PM
  5. VM2 Cuts too deep
    By paul smargiassi in forum HURCO
    Last Post: 05-15-2011, 11:14 PM
