586,033 active members*
3,368 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Moriseiki ZL20 -MF-D4 control(1991) and Moriseiki ZL200- MSC-500(1999), G and M code
Results 1 to 3 of 3
    Mar 2015
    3
    Hi everybody
    I Have a problem with Fanuc control . Now i want to machining work part with A Turret both B turret in main spindle
    But i don't know how to Idle stop Turret A or B to waiting for A or B Turret go to end block command
    Ex : A turret now is machining, next step B Turret must be machining
    How to call B turret to machining in Head 1 program ?
    If can't call B Turret in Head 1, how to call B turret waiting for A turret end in Head 2 Program?
    Because when MEM select key, A and B Turret also selected automatic, I Belive that must be make 2 programs for HEAD 1 and HEAD 2
    In ZL200SMC machine, how to make program for both main with A Turrer maching and sub spindle with B turret machining? In Main spindle- X and is positive and Z is negative but , when make program for Sub spindle, how to do ?
    I haven't any manual Programing because all machining are second hand machining
    Re: Moriseiki ZL20 -MF-D4 control(1991) and Moriseiki ZL200- MSC-500(1999), G and M c
    You didn't say which Fanuc controller you have so I have to guess. I picked the 18TT control. If it’s different then we are going to have to know that. What Fanuc gives you is two parameters where you set the Range of M codes that you want to wait with. So lets say you put in 55 in parameter 8111 and 56 in parameter 8112 then the control will look for M55 in either head then hold that head up till it sees the M55 in the other head. Then both heads take off together again.
    Mar 2015
    3
    Thankyou for your support,
    I have find about, Mcode, it using M110 and M120 in sub program and main program
    My control is Fanuc OM and Fanuc 18
  1. Moriseiki CL200 with Mitsubishi msc 803L controller
    By yashika_patil in forum Machinery Manuals / Brochures
    Last Post: 07-21-2020, 10:00 AM
  2. MoriSeiki SL80C
    By tnhoai in forum Mori Seiki lathes
    Last Post: 07-16-2014, 07:57 AM
