586,469 active members*
2,942 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Question about PWM - do I need it to control my NEJE 30W laser
    Mar 2018
    I'm in the final stages of a build for a laser engraver. Right now I'm using an Arduino Uno r3 with a Protoneer CNC Shield to control motion. The CNC Shield has outputs for Spindle Enable and Direction, but I don't see anything for PWM control. My question is, do I need PWM control for the laser to control the power. If I do, any recommendation for a controller board that will fill the bill? I am totally new to laser technology, so please go easy on me. I don't know if i am leaving out any pertinent information, so please ask questions and I'll do my bet to answer them. I was planning to use LaserGRBL, but would be open to using other software if it would be better suited to my hardware. Lightburn or...
    Joe Melhorn
    Sahuarita, AZ
    Apr 2005
    304
    Cool Re: Question about PWM - do I need it to control my NEJE 30W laser
    I guess that you need PWM for laser power control.
    To be able to control power, parameter $32 should be set to 1 ($32=1) - Laser mode ON
    PWM output is available at the circled pins.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Need help with PWM laser control in Mach3
    By garymiller397 in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 12-01-2022, 07:55 PM
  2. Need help with pwm control of a laser
    By garymiller397 in forum Machines running Mach Software
    Last Post: 04-12-2020, 10:14 PM
  3. Seaking advice to Mod Mini Laser engraver 'NEJE' with GRBL board and stronger laser.
    By BubbleBob in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-31-2018, 11:07 PM
  4. Laser Control by Spindle PWM
    By wl888 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-02-2016, 01:06 AM
  5. Laser PWM Question??
    By shadowbird in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-11-2012, 09:27 PM
