586,058 active members*
4,100 visitors online*
    Apr 2007
    32
    SV-503/40 alarm 410 z-axis
    The machine is a SV-503/40 with fanuc 18i-m model a
    The alarm 410 for z-axis will randomly pop up when I unlock the door or m30 is commanded in a program and the z-axis brake is engaged.
    I increased parameter 1829 value a few hundred after observing what the value at DGN was hitting and that seemed to help a lot.
    fanuc troubleshooting manual says to check DGN G126 bits 0-7 for '1' when axis is clamped and i get only zeros
    can I just increase the parameter 1829 value until this problem goes away without any undesirable side effects? are there any common issues i can check or should i just follow the trouble shooting flowchart?
    Mar 2008
    31
    Re: SV-503/40 alarm 410 z-axis
    probably the brake or timing belt issue.
  1. 410 Alarm X axis ecess error
    By scuba in forum Fanuc
    Last Post: 02-19-2024, 07:39 PM
  2. Replies: 12
    Last Post: 01-12-2023, 10:58 AM
  3. Replies: 6
    Last Post: 01-14-2011, 05:16 AM
  4. Alarm 410 V axis Excess Error, FIX?
    By D_Flannery in forum Fanuc
    Last Post: 01-14-2011, 05:13 AM
  5. Fanuc 18I Z axis servo Alarm 410
    By Ninus in forum Fanuc
    Last Post: 09-22-2006, 05:16 AM
