586,062 active members*
4,756 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > help please with Z axis travel distance
    Jul 2018
    31
    ok guy's so this should be my last question regarding this set up.
    i have all axis working fine now bearing in mind i have only checked my Z axis with this test, i set up my dial indicator to measure a 'step' in the down direction.
    so the stepper motors are geared but on a 1 : 1 basis, the steps per unit are set at 200, the Z axis indicates 1 unit of movement (all units are set as mm) but the dial indicator measures .68mm of travel
    am i missing something?
    thanks neil
    Nov 2008
    643
    Re: help please with Z axis travel distance
    There are a lot of parameters involved with calculating that number. And it changes from inch to mm.
    I found the best way is to measure the distance traveled over the largest travel and keep adjusting that setup multiplier until the distance on the controller matches the actual distance traveled. Try and try again method.
    Jun 2013
    443
    Do you have any backlash? So if you go for 10mm do you get 9.68mm or 6.8mm.
    If you are finding the Z is out the other axis lengths will be as well if you have the same settings to ballscews.
    Double check all parts especially your coupling for any slippage or backlash.
    Sent from my SM-N970F using Tapatalk
    Jul 2018
    31
    dean, thanks for the reply i will have a go at that method
    boydage, i only tried the Z axis and only over 1 unit which should be 1mm, there doesn't seem to be any back lash in my gear set up but could be in the machines set up, i will check it out
    thanks for the replies guys
    thanks neil
    Jul 2018
    31
    ok so thanks to those that replied to my predicament lol, i have it dialed in now
    i removed the gearing and made brackets for direct drive on the shafts, i then ran the calibration tool on the axis setup tab which was a big help, that got me close enough to perfect
    thanks again
  1. Z axis travel distance?
    By NogginBoink in forum Open Source CNC Machine Designs
    Last Post: 11-11-2013, 05:38 AM
  2. Travel is not on exact distance
    By FastFieros in forum Fadal
    Last Post: 11-03-2010, 11:33 PM
  3. Z Axis Travel Distance
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 06-01-2010, 12:57 AM
  4. Mach 3 travel distance HELP! Please.
    By CompositeCraft in forum Mach Software (ArtSoft software)
    Last Post: 09-26-2009, 04:09 AM
  5. distance z axis can travel
    By mostlund in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:04 AM
