586,080 active members*
3,729 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Kollmorgan drive and kitagawa rotary table
Results 1 to 5 of 5
    Jun 2008
    8
    I have an Cincinnati Arrow. Years ago I bought a Kitagawa rotary off EBay, rotary model TB160 as I recall. The rotary has its own control box. However the machine is pre-wired for another drive.
    If possible I would like to control the 4th rotary from the machine control.
    Will a kollmorgan drive run this kitagawa rotary or is there more to this that I need to know and do.
    Mar 2008
    285
    Re: Kollmorgan drive and kitagawa rotary table
    Sarms,
    You would need a Kollmorgen Motor with amps to match the Drive.
    You do not say if it was a Kollmorgen BDS4 Drive, or a Kollmorgen Servo-Star. The motors are quite different.
    Jun 2008
    8
    Quote Originally Posted by gwood View Post
    Sarms,
    It's a BDS4 drive.
    Mar 2008
    285
    Sarms, A BDS4 Drive has a sticker with a Model Type
    i.e. Drive Type: BDS4-206-23-412W32 (A-axis 6-Amp) Motor Type : A axis 1-604-0210
    Sep 2010
    1765
    There is a small chance the BDS4 can run your motor; list your motor part number - and specs if you have them - and we can tell you if it can work.
  1. Which rotary table vs. which inexpensive harmonic drive setup?
    By Chuck Bogardus in forum Benchtop Machines
    Last Post: 08-18-2019, 06:08 PM
  2. Kitagawa S1246 rotary hydaulic cylinder
    By hotrob1 in forum Uncategorised MetalWorking Machines
    Last Post: 01-22-2013, 03:29 PM
  3. What size stepper to drive a 10" rotary table?
    By fido in forum Stepper Motors / Drives
    Last Post: 11-12-2008, 12:57 PM
  4. Chatter on rotary table worm drive
    By replicapro in forum Benchtop Machines
    Last Post: 08-21-2006, 11:31 PM
