586,052 active members*
4,157 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > removing z axis motor and manually lowering z to fit under door
    May 2021
    Question removing z axis motor and manually lowering z to fit under door
    Does anyone know if you can remove z axis servo motor and lower the z manually to fit under doorway on 3 axis cnc mill?
    Dec 2013
    5717
    Re: removing z axis motor and manually lowering z to fit under door
    Yes, it's possible to do that. Be careful that the Z axis does not fall when you remove the motor.
    Jim Dawson
    Sandy, Oregon, USA
