Just for reference in Mach3 or Mach4 I use the following post in Vectric:
Mach 2/3 Arcs (mm)(*.txt)
Has anyone recommended that you post your gcode to this thread?
Thanks one again guys, very much appreciated
Okay a good update!
I made the internal cabinet tidy
I recall someone saying once that the Chinese controllers via USB can be temprimental and always better with CAT Style plug or the older style big parrell plugs
So after i did that i made a new G Gode and sent that to the machne
It cut it perfectly on 2 x passes
But
It was using Softcore board!
So im not 100% but maybe its one of these three things!
1: Dodgy interference via USB Cable but it is a sheilded cable im using! Interference from another source, or simply its cause its a USB out from controller to the PC
2: The motors struggle on the 3rd pass on thicker wood! will require further testing though
3: G Code issue?
im still thinking 1,2 is the culprit
The binding seems to happen and puts it off course, but this new cut was 100% but thats after i moved the NVUM controller to the rear of the enclosure and checked all the cables etc and it was only cutting softcore board not thicker dense ply
Will update guys!
the new okay cut!
here is how i saved the new g code
then sent to mach 3
I’d recommend using the post I referenced for Mach3.
USB can indeed be ‘dodgy’. Don’t try using USB cables over 1m. Ethernet is much smoother at longer lengths. However it’s a noise issue with USB and wouldn’t happen at the same spot in the cut over multiple trials.
If your using USB interface, you appear to have some EMI issues. Get two EMI donuts, these look like life saver candy but they are magnet cores. Loop each end of the USB cable through the donuts about three or four times. Make sure they are on both ends and you will see a huge improvement in EMI interference.
Russ
Well this morning i made a quick sign and was very happy it done okay on two passes:
However on my second cut this afternoon it went haywire again lol
So not sure is it my G Code? or is it Interference? or is it dodgy nema 23 not having the stregth to pull over the wood, i think not as it seems to
Just go way off what i want it to do!
so what you guys rekon?
Is it my dodgy G Code? maybe im saving it wrong ??? as there is a lot off different options to save as?
Or is it interference? bad connection etc
what it looks like on aspre
what it looks like when it was cutting
I think you have already proven it is NOT the gcode. It cut some previous examples fine. You have interference from EMI, get some EMI donuts or a USB isolator kits to address the noise.
Russ
I'm a bit late to this thread and wouldn't claim to know the answers.What I always believe is that the simulation of the program shows you what the machine will be receiving instructions for.As long as you pick the correct post processor and the mechanical aspects of the machine are sound,it comes back to the quality of the pulses received at the steppers.As you have found by moving some components around things seem less bad then a bit more focus on shielding will probably pay dividends.Just out of curiosity,are you located very far from the nearest sub-station and with tree branches brushing against power supply cables?
HI
I did the USB With ferrite cores and tidyed up the control panel
It did one cut on plywood 3 x passes 100% ok
Then i made another cut this time on perspex and it coked up straight away
Im thinking maybe its the Feedrates now on Mach3
Or motor tuning or
Belts are too tight and struggle under a load?
As its cocked up a few times on perspex or the deeper cuts
mmmmmmmmmmm
Im not giving up guys!
Not near a sub station or that cables underground!
Pic on wood cut okay perspex ballsed up
Pic showing cable track maybe too tight?
Pic showing inside cabinet been using EMI power and ferrites
MMMMMMMMMMM
Could also be the Windows 7 PC
As the Wireless Mouse and Keyboard dont work 90% of the time, PITA now
Im going to try this on another PC soon! (chair)
How about a bit more information about the depth of cut and feed rates you are using?You might be asking the machine to do more than it has the power to achieve.Most of the commercial cutter suppliers will have recommendations for their hardware when used on commercial machines and trying to match them on a hobby machine may lead to disappointment.
Thanks for the replys
Yes that is what i was thinking also! Maybe its under too much load
This was a UK Made machine called routout CNC
I changed the motors to Nema 23 but there is only one on the Y axis
Today im going to try on a new PC
At least that will rule out my PC
I then also have a NEW contoller board to try China nMotion controller
If i try these two things and still get issues we can rule out the PC and controller and narrow it down too
In no particular order lol
Noise
Mecahnics belt too tight, tight bolts nuts
and of course not enough power!
Will update
Thanks guys!
FFS!
Its happening still
I just installed a new motion controller
ZKMotion Mach3 4 Axis USB CNC Motion Card
And now my drivers use 4 x wires insted of 3 before
Still im getting cocked up signs lol
I sit Motor tuning? this is something im still working on guys!
with the new controller! Seems to do its own thing and doesnt follow the sip[le GCode as attached
any ideas guys
T1M6
G17
G0Z20.000
G0X0.000Y0.000S12000M3
G0X-45.428Y6.621Z6.000
G1Z-3.000F762.0
G1X-45.832Y6.170F2540.0
X-45.428Y5.720
X-45.023Y6.170
X-45.428Y6.621
G0Z6.000
G0X-41.040Y-12.196
G1Z-3.000F762.0
G1X-41.673Y-12.342F2540.0
X-42.079Y-12.379
X-42.415Y-12.367
X-42.717Y-12.331
X-43.013Y-12.269
X-43.301Y-12.179
X-43.579Y-12.062
X-43.843Y-11.916
X-44.091Y-11.743
X-44.332Y-11.534
X-44.563Y-11.269
X-44.757Y-10.960
X-44.907Y-10.630
X-45.020Y-10.284
X-45.101Y-9.921
X-45.156Y-9.539
X-45.188Y-9.137
X-45.198Y5.022
X-45.187Y5.167
X-45.154Y5.316
X-45.095Y5.464
X-45.012Y5.604
X-44.905Y5.730
X-44.779Y5.836
X-44.639Y5.920
X-44.492Y5.978
X-44.343Y6.012
X-44.198Y6.022
X-40.034Y6.031
X-39.962Y6.068
X-39.962Y6.168
X-40.074Y6.301
X-40.150Y6.318
X-44.198
X-44.343Y6.329
X-44.492Y6.363
X-44.639Y6.421
X-44.779Y6.505
X-44.905Y6.611
X-45.012Y6.737
X-45.095Y6.877
X-45.154Y7.025
X-45.187Y7.174
X-45.198Y7.318
X-45.208Y11.945
X-45.257Y12.040
X-45.353Y12.089
X-45.503
X-45.599Y12.040
X-45.648Y11.945
X-45.658Y7.318
X-45.668Y7.174
X-45.702Y7.025
X-45.760Y6.877
X-45.844Y6.737
X-45.951Y6.611
X-46.077Y6.505
X-46.217Y6.421
X-46.364Y6.363
X-46.513Y6.329
X-46.658Y6.318
X-49.708Y6.310
X-49.801Y6.261
X-49.832Y6.213
X-49.822Y6.104
X-49.741Y6.040
X-49.608Y6.022
X-46.658
X-46.513Y6.012
X-46.364Y5.978
X-46.217Y5.920
X-46.077Y5.836
X-45.951Y5.730
X-45.844Y5.604
X-45.760Y5.464
X-45.702Y5.316
X-45.668Y5.167
X-45.658Y5.022
Y-8.824
X-45.646Y-9.332
X-45.613Y-9.783
X-45.559Y-10.188
X-45.486Y-10.545
X-45.397Y-10.853
X-45.296Y-11.114
X-45.185Y-11.327
X-45.058Y-11.515
X-44.746Y-11.871
X-44.449Y-12.131
X-44.189Y-12.290
X-43.956Y-12.374
X-43.587Y-12.448
X-43.171Y-12.504
X-42.718Y-12.539
X-42.246Y-12.550
X-41.911Y-12.531
X-41.634Y-12.481
X-41.394Y-12.403
X-41.104Y-12.249
X-41.012Y-12.180Z-2.991
X-40.930Y-12.202Z-2.912
X-40.922Y-11.983Z-2.806
X-40.919Y-11.973Z-2.796
X-41.003Y-12.169Z-2.982
X-41.040Y-12.196Z-3.000
G0Z6.000
G0X-34.306Y-1.734
G1Z-3.000F762.0
G1X-34.324Y-1.972F2540.0
X-34.182Y-1.867
X-34.306Y-1.734
G0Z6.000
G0X-25.108Y6.827
G1Z-3.000F762.0
G1X-25.648Y6.876F2540.0
X-26.197Y6.892
X-26.752Y6.873
X-27.295Y6.818
X-27.830Y6.726
X-28.356Y6.596
X-28.875Y6.430
X-29.388Y6.226
X-29.896Y5.984
X-30.396Y5.704
X-30.878Y5.390
X-31.333Y5.045
X-31.764Y4.666
X-32.171Y4.253
X-32.556Y3.804
X-32.919Y3.319
X-33.259Y2.798
X-33.575Y2.241
X-33.858Y1.656
X-34.104Y1.049
X-34.312Y0.415
X-34.484Y-0.247
X-34.618Y-0.936
X-34.715Y-1.655
X-34.773Y-2.402
X-34.793Y-3.177
X-34.773Y-3.910
X-34.714Y-4.617
X-34.617Y-5.297
X-34.482Y-5.952
X-34.309Y-6.582
X-34.098Y-7.187
X-33.850Y-7.770
X-33.564Y-8.330
X-33.244Y-8.865
X-32.895Y-9.368
X-32.518Y-9.838
X-32.111Y-10.277
X-31.675Y-10.686
X-31.208Y-11.064
X-30.710Y-11.414
X-30.180Y-11.734
X-29.625Y-12.020
X-29.049Y-12.267
X-28.450Y-12.477
X-27.828Y-12.650
X-27.182Y-12.785
X-26.511Y-12.882
X-25.814Y-12.940
X-25.093Y-12.960
X-24.601Y-12.946
X-24.117Y-12.903
X-23.641Y-12.832
X-23.171Y-12.732
X-22.708Y-12.604
X-22.250Y-12.447
X-21.796Y-12.262
X-21.345Y-12.045
X-20.902Y-11.804
X-20.478Y-11.546
X-20.075Y-11.272
X-19.693Y-10.984
X-19.331Y-10.680
X-18.988Y-10.362
X-18.666Y-10.027
X-18.191Y-9.462
X-18.188Y-9.455
X-18.131Y-9.446Z-2.947
X-18.188Y-9.455Z-3.000
X-18.250Y-9.393
X-18.242Y-9.340Z-2.950
X-18.250Y-9.393Z-3.000
X-18.407Y-9.482
X-18.585Y-9.707
X-18.889Y-10.049
X-19.215Y-10.373
X-19.561Y-10.679
X-19.927Y-10.968
X-20.313Y-11.239
X-20.717Y-11.493
X-21.145Y-11.732
X-21.595Y-11.950
X-22.064Y-12.141
X-22.546Y-12.303
X-23.041Y-12.434
X-23.547Y-12.535
X-24.065Y-12.608
X-24.594Y-12.651
X-25.134Y-12.665
X-25.816Y-12.646
X-26.480Y-12.587
X-27.126Y-12.490
X-27.754Y-12.352
X-28.362Y-12.173
X-28.950Y-11.954
X-29.515Y-11.694
X-30.056Y-11.394
X-30.567Y-11.062
X-31.048Y-10.700
X-31.500Y-10.309
X-31.922Y-9.887
X-32.314Y-9.437
X-32.674Y-8.958
X-33.003Y-8.453
X-33.299Y-7.921
X-33.563Y-7.368
X-33.790Y-6.798
X-33.982Y-6.211
X-34.139Y-5.609
X-34.260Y-4.992
X-34.347Y-4.360
X-34.398Y-3.714
X-34.415Y-3.080
X-34.409Y-2.947
X-34.384Y-2.809
X-34.338Y-2.671
X-34.271Y-2.537
X-34.182Y-2.413
X-34.076Y-2.304
X-33.954Y-2.212
X-33.822Y-2.141
X-33.685Y-2.092
X-33.548Y-2.063
X-33.415Y-2.054
X-17.867Y-2.046
X-17.747Y-1.978
X-17.695Y-1.901
X-17.716Y-1.190
X-17.781Y-0.530
X-17.884Y0.102
X-18.023Y0.706
X-18.198Y1.283
X-18.408Y1.834
X-18.653Y2.359
X-18.937Y2.864
X-19.252Y3.346
X-19.590Y3.799
X-19.948Y4.219
X-20.326Y4.608
X-20.726Y4.966
X-21.147Y5.294
X-21.591Y5.592
X-22.059Y5.863
X-22.546Y6.104
X-23.042Y6.313
X-23.546Y6.490
X-24.057Y6.635
X-24.578Y6.747
X-25.108Y6.827
G0Z6.000
G0X-24.364Y6.311
G1Z-3.000F762.0
G1X-23.915Y6.196F2540.0
X-23.471Y6.057
X-23.032Y5.892
X-22.596Y5.703
X-22.168Y5.487
X-21.754Y5.245
X-21.358Y4.980
X-20.980Y4.691
X-20.620Y4.378
X-20.279Y4.042
X-19.958Y3.684
X-19.656Y3.302
X-19.374Y2.897
X-19.121Y2.472
X-18.897Y2.030
X-18.704Y1.572
X-18.542Y1.099
X-18.409Y0.612
X-18.307Y0.111
X-18.229Y-0.442
Y-0.840
X-18.239Y-0.985
X-18.273Y-1.134
X-18.332Y-1.282
X-18.415Y-1.422
X-18.522Y-1.548
X-18.648Y-1.654
X-18.788Y-1.738
X-18.935Y-1.796
X-19.084Y-1.830
X-19.229Y-1.840
X-33.210
X-33.344Y-1.832
X-33.482Y-1.803
X-33.621Y-1.752
X-33.756Y-1.678
X-33.881Y-1.582
X-33.990Y-1.466
X-34.080Y-1.334
X-34.146Y-1.191
X-34.189Y-1.044
X-34.208Y-0.897
X-34.206Y-0.755
X-34.186Y-0.623
X-34.012Y0.159
X-33.778Y0.935
X-33.494Y1.659
X-33.148Y2.359
X-32.750Y3.006
X-32.299Y3.605
X-31.793Y4.155
X-31.231Y4.656
X-30.663Y5.082
X-30.072Y5.458
X-29.464Y5.778
X-28.839Y6.043
X-28.198Y6.249
X-27.543Y6.397
X-26.876Y6.486
X-26.207Y6.515
X-25.735Y6.502
X-25.275Y6.464
X-24.818Y6.400
X-24.364Y6.311
G0Z6.000
G0X0.574Y-5.863
G1Z-3.000F762.0
G1X0.836Y-6.289F2540.0
X1.039Y-6.749
X1.180Y-7.234
X1.262Y-7.739
X1.288Y-8.263
X1.260Y-8.800
X1.171Y-9.320
X1.020Y-9.820
X0.804Y-10.292
X0.526Y-10.730
X0.191Y-11.128
X-0.197Y-11.482
X-0.625Y-11.788
X-1.071Y-12.047
X-1.528Y-12.268
X-2.001Y-12.454
X-2.491Y-12.605
X-2.996Y-12.722
X-3.515Y-12.805
X-4.047Y-12.854
X-4.590Y-12.870
X-5.139Y-12.856
X-5.676Y-12.814
X-6.202Y-12.745
X-6.717Y-12.646
X-7.221Y-12.519
X-7.712Y-12.364
X-8.190Y-12.179
X-8.655Y-11.966
X-9.106Y-11.724
X-9.542Y-11.454
X-9.963Y-11.157
X-10.368Y-10.833
X-10.757Y-10.482
X-11.129Y-10.105
X-11.486Y-9.702
X-11.751Y-9.370
X-11.873Y-9.280
X-11.935Y-9.267
X-11.976Y-9.158Z-2.890
X-11.935Y-9.267Z-3.000
X-12.100Y-9.381
X-12.283Y-9.308Z-2.834
X-12.100Y-9.381Z-3.000
X-11.965Y-9.660
X-11.664Y-10.020
X-11.309Y-10.403
X-10.940Y-10.757
X-10.559Y-11.083
X-10.166Y-11.383
X-9.758Y-11.655
X-9.338Y-11.902
X-8.903Y-12.122
X-8.453Y-12.317
X-7.987Y-12.486
X-7.505Y-12.630
X-7.007Y-12.748
X-6.492Y-12.840
X-5.958Y-12.907
X-5.407Y-12.947
X-4.842Y-12.960
X-4.130Y-12.937
X-3.459Y-12.870
X-2.824Y-12.760
X-2.224Y-12.607
X-1.658Y-12.412
X-1.124Y-12.176
X-0.620Y-11.898
X-0.137Y-11.572
X0.274Y-11.234
X0.627Y-10.871
X0.919Y-10.488
X1.156Y-10.083
X1.340Y-9.650
X1.473Y-9.185
X1.555Y-8.683
X1.583Y-8.140
X1.571Y-7.718
X1.535Y-7.327
X1.477Y-6.966
X1.399Y-6.635
X1.301Y-6.332
X1.184Y-6.057
X1.050Y-5.806
X0.892Y-5.570
X0.506Y-5.112
X0.062Y-4.703
X-0.439Y-4.347
X-0.998Y-4.043
X-1.687Y-3.746
X-2.473Y-3.459
X-3.359Y-3.182
X-5.034Y-2.734
X-6.293Y-2.349
X-6.865Y-2.146
X-7.399Y-1.935
X-7.897Y-1.715
X-8.358Y-1.485
X-8.791Y-1.239
X-9.205Y-0.956
X-9.586Y-0.626
X-9.920Y-0.257
X-10.203Y0.152
X-10.429Y0.593
X-10.596Y1.063
X-10.705Y1.553
X-10.761Y2.084
X-10.733Y2.651
X-10.651Y3.171
X-10.510Y3.671
X-10.308Y4.144
X-10.046Y4.584
X-9.726Y4.986
X-9.354Y5.343
X-8.942Y5.649
X-8.513Y5.907
X-8.072Y6.126
X-7.613Y6.310
X-7.137Y6.459
X-6.645Y6.574
X-6.139Y6.656
X-5.618Y6.704
X-5.087Y6.720
X-4.651Y6.710
X-4.223Y6.679
X-3.800Y6.629
X-3.384Y6.557
X-2.973Y6.466
X-2.569Y6.353
X-2.172Y6.220
X-1.782Y6.066
X-1.400Y5.892
X-1.030Y5.698
X-0.673Y5.484
X-0.328Y5.250
X0.003Y4.998
X0.320Y4.727
X0.623Y4.437
X0.918Y4.140
X0.987Y4.149
X1.000Y4.127Z-2.976
X0.987Y4.149Z-3.000
X1.042Y4.224
X1.042Y4.290
X1.068Y4.302Z-2.972
X1.042Y4.290Z-3.000
X0.637Y4.723
X0.339Y5.012
X0.029Y5.278
X-0.294Y5.522
X-0.631Y5.743
X-0.982Y5.944
X-1.348Y6.123
X-1.733Y6.282
X-2.538Y6.550
X-3.339Y6.741
X-4.132Y6.854
X-4.921Y6.892
X-5.379Y6.882
X-5.823Y6.851
X-6.252Y6.799
X-6.665Y6.727
X-7.063Y6.636
X-7.447Y6.525
X-7.818Y6.394
X-8.175Y6.244
X-8.515Y6.077
X-8.835Y5.895
X-9.133Y5.699
X-9.411Y5.490
X-9.669Y5.266
X-9.909Y5.028
X-10.131Y4.775
X-10.334Y4.507
X-10.515Y4.231
X-10.669Y3.950
X-10.798Y3.662
X-10.904Y3.365
X-10.987Y3.059
X-11.046Y2.742
X-11.082Y2.413
X-11.088Y1.789
X-11.038Y1.264
X-10.940Y0.789
X-10.798Y0.359
X-10.612Y-0.031
X-10.382Y-0.385
X-10.104Y-0.711
X-9.774Y-1.012
X-9.589Y-1.152
X-9.135Y-1.454
X-8.635Y-1.744
X-8.084Y-2.023
X-7.485Y-2.291
X-6.835Y-2.547
X-6.137Y-2.789
X-5.389Y-3.018
X-3.978Y-3.398
X-2.843Y-3.755
X-2.321Y-3.948
X-1.828Y-4.152
X-1.366Y-4.367
X-0.932Y-4.594
X-0.517Y-4.842
X-0.113Y-5.133
X0.256Y-5.476
X0.574Y-5.863
G0Z6.000
G0X10.496Y5.720
G1Z-3.000F762.0
G1X10.900Y6.170F2540.0
X10.496Y6.621
X10.092Y6.170
X10.496Y5.720
G0Z6.000
G0X14.884Y-12.196
G1Z-3.000F762.0
G1X14.251Y-12.342F2540.0
X13.844Y-12.379
X13.509Y-12.367
X13.207Y-12.331
X12.911Y-12.269
X12.622Y-12.179
X12.345Y-12.062
X12.080Y-11.916
X11.833Y-11.743
X11.592Y-11.534
X11.361Y-11.269
X11.166Y-10.960
X11.017Y-10.630
X10.904Y-10.284
X10.822Y-9.921
X10.767Y-9.539
X10.736Y-9.137
X10.726Y5.022
X10.737Y5.167
X10.770Y5.316
X10.829Y5.464
X10.912Y5.604
X11.019Y5.730
X11.145Y5.836
X11.285Y5.920
X11.432Y5.978
X11.581Y6.012
X11.726Y6.022
X15.890Y6.031
X15.962Y6.068
X15.961Y6.168
X15.850Y6.301
X15.773Y6.318
X11.726
X11.581Y6.329
X11.432Y6.363
X11.285Y6.421
X11.145Y6.505
X11.019Y6.611
X10.912Y6.737
X10.829Y6.877
X10.770Y7.025
X10.737Y7.174
X10.726Y7.318
X10.716Y11.945
X10.667Y12.040
X10.571Y12.089
X10.421
X10.325Y12.040
X10.276Y11.945
X10.266Y7.318
X10.255Y7.174
X10.222Y7.025
X10.163Y6.877
X10.080Y6.737
X9.973Y6.611
X9.847Y6.505
X9.707Y6.421
X9.560Y6.363
X9.411Y6.329
X9.266Y6.318
X6.216Y6.310
X6.123Y6.261
X6.092Y6.213
X6.102Y6.104
X6.183Y6.040
X6.316Y6.022
X9.266
X9.411Y6.012
X9.560Y5.978
X9.707Y5.920
X9.847Y5.836
X9.973Y5.730
X10.080Y5.604
X10.163Y5.464
X10.222Y5.316
X10.255Y5.167
X10.266Y5.022
Y-8.824
X10.278Y-9.332
X10.311Y-9.783
X10.365Y-10.188
X10.438Y-10.545
X10.527Y-10.853
X10.628Y-11.114
X10.739Y-11.327
X10.866Y-11.515
X11.178Y-11.871
X11.475Y-12.131
X11.735Y-12.290
X11.968Y-12.374
X12.337Y-12.448
X12.753Y-12.504
X13.206Y-12.539
X13.678Y-12.550
X14.012Y-12.531
X14.290Y-12.481
X14.530Y-12.403
X14.820Y-12.249
X14.912Y-12.180Z-2.991
X14.993Y-12.202Z-2.912
X15.002Y-11.983Z-2.806
X15.004Y-11.973Z-2.796
X14.920Y-12.169Z-2.982
X14.884Y-12.196Z-3.000
G0Z6.000
G0X33.866Y11.933
G1Z-3.000F762.0
G1X34.123Y11.960F2540.0
X34.123Y12.527
X33.908Y12.544
X33.710Y12.531
X33.561Y12.500
X33.568Y11.968
X33.673Y11.945
X33.866Y11.933
G0Z6.000
G0X34.086Y6.615
G1Z-3.000F762.0
G1X34.037Y6.710F2540.0
X33.941Y6.759
X33.791
X33.695Y6.710
X33.646Y6.615
X33.636Y6.497
X33.646Y-12.396
X33.695Y-12.491
X33.791Y-12.540
X33.941
X34.037Y-12.491
X34.086Y-12.396
X34.096Y-12.278
X34.086Y6.615
G0Z6.000
G0X33.163Y11.837
G1Z-3.000F762.0
G1X33.215Y11.702F2540.0
X33.318Y11.617
X33.413Y11.578
X33.616Y11.534
X33.866Y11.518
X34.113Y11.534
X34.348Y11.591
X34.461Y11.666
X34.519Y11.787
X34.547Y12.072
Y12.407
X34.518Y12.715
X34.456Y12.846
X34.349Y12.902
X34.155Y12.943
X33.907Y12.959
X33.654Y12.943
X33.394Y12.880
X33.231Y12.777
X33.171Y12.667
X33.144Y12.423
Y12.074
X33.163Y11.837
G0Z6.000
G0X44.362Y5.720
G1Z-3.000F762.0
G1X44.766Y6.170F2540.0
X44.362Y6.621
X43.957Y6.170
X44.362Y5.720
G0Z6.000
G0X48.750Y-12.196
G1Z-3.000F762.0
G1X48.117Y-12.342F2540.0
X47.710Y-12.379
X47.375Y-12.367
X47.073Y-12.331
X46.777Y-12.269
X46.488Y-12.179
X46.210Y-12.062
X45.946Y-11.916
X45.699Y-11.743
X45.458Y-11.534
X45.226Y-11.269
X45.032Y-10.960
X44.882Y-10.630
X44.770Y-10.284
X44.688Y-9.921
X44.633Y-9.539
X44.602Y-9.137
X44.592Y5.022
X44.602Y5.167
X44.636Y5.316
X44.694Y5.464
X44.778Y5.604
X44.885Y5.730
X45.011Y5.836
X45.151Y5.920
X45.298Y5.978
X45.447Y6.012
X45.592Y6.022
X49.756Y6.031
X49.828Y6.068
X49.827Y6.168
X49.716Y6.301
X49.639Y6.318
X45.592
X45.447Y6.329
X45.298Y6.363
X45.151Y6.421
X45.011Y6.505
X44.885Y6.611
X44.778Y6.737
X44.694Y6.877
X44.636Y7.025
X44.602Y7.174
X44.592Y7.318
X44.582Y11.945
X44.533Y12.040
X44.437Y12.089
X44.287
X44.191Y12.040
X44.142Y11.945
X44.132Y7.318
X44.121Y7.174
X44.088Y7.025
X44.029Y6.877
X43.946Y6.737
X43.839Y6.611
X43.713Y6.505
X43.573Y6.421
X43.426Y6.363
X43.277Y6.329
X43.132Y6.318
X40.082Y6.310
X39.989Y6.261
X39.958Y6.213
X39.968Y6.104
X40.048Y6.040
X40.182Y6.022
X43.132
X43.277Y6.012
X43.426Y5.978
X43.573Y5.920
X43.713Y5.836
X43.839Y5.730
X43.946Y5.604
X44.029Y5.464
X44.088Y5.316
X44.121Y5.167
X44.132Y5.022
Y-8.824
X44.143Y-9.332
X44.177Y-9.783
X44.231Y-10.188
X44.304Y-10.545
X44.392Y-10.853
X44.494Y-11.114
X44.605Y-11.327
X44.732Y-11.515
X45.044Y-11.871
X45.341Y-12.131
X45.601Y-12.290
X45.834Y-12.374
X46.203Y-12.448
X46.619Y-12.504
X47.071Y-12.539
X47.544Y-12.550
X47.878Y-12.531
X48.156Y-12.481
X48.395Y-12.403
X48.686Y-12.249
X48.778Y-12.180Z-2.991
X48.859Y-12.202Z-2.912
X48.868Y-11.983Z-2.806
X48.870Y-11.973Z-2.796
X48.786Y-12.169Z-2.982
X48.750Y-12.196Z-3.000
G0Z6.000
G0Z20.000
G0X0.000Y0.000
M30
I THINK!!!!!!!!!!!!!!!!
Ive just made a major discovery!
When switched the X Axis and the Z Axis is SOLID! When you Push or Pull these two axis it doesnt move!
The Y Axis Moves manually Easily bby about 1cm back and forth! Now that must be the issue?
Somewhere somewhow the Y Axis is moving freely by about 1cm before being the same as the X and Z
So it has to be something to do with my Y Axis
Im not sure now if its mechanical or its a fault in the motor etc, But i think its been established that its a mechanical fault somewhere on the Y axis
wherever its the belt, bolts, nuts or nema 23 issue!
Y AXIS I think is the culprit
Working on that now!
THANKS VERY MUCH TO ALL THE PEOPLE THAT HELPED ME ON THIS!!!!!!!!!!!!!!!!
SO
It was simply a case of Y AXIS NEMA 23
Dropped down from the holder
They dont make those Nema 23 easy to mount as its very tedious trying to tighten them without snapping the screws! that hold the nema in place a little more space to mount the nylocc nuts and tighten them would be better!
Still so happy now!
I did 4 x 3mm around that passes and cut very well after i lefted the Nema 23 up! I will make sure that the belet is tightened always!
So guys the answer was if you have play in your AXIS Check the belt, rods etc!
If you get messed up G Codes like mine lol
Maybe a Motor isnt tightened
It must be a huge relief.It hardly ever comes down to a fault with the CAM program,as long as you select the correct post processor amd you could have downloaded the free Camotics program to verify the code.Which would have set you on the path to checking out the mechanical aspects of the machine.I suspect a regular inspection of the machine will be part of the workshop routine in future won't it?
HI routalot
I will be making good use of it for 2-3 months so i can sell it knowing that its 100%
Im going to build a new one from scratch using Rexroth strut and the chinese heavy duty spindle so i can do alumimum and other woods!
I wanted to do another test cut before replying inase it ballsed up again but im sure that its all for now
Over the next few weeks hopefully master the homing and limit switched etc and my Z still lifts too high so will look into that next!
Then the homing positions!
Wooh so much work and too learn! But im multi tasking with other things, making it taking me much longer!
But im super happy to have made this small cut! i think my motors need tweaking also a bit grunty!
But the main thing is its falling the paths and im very pleased! ordered new stainless steel HEX Bolts today M5 25mm TO HELP SECURE THE NEMA 23 BETTER SO doesnt slip again! that was the issue the nema 23 had moved down making the belt slack!
Solid now
Thanks everyone who replied to this topic!
I will be back with new questions no doubt lol
Adam
