586,100 active members*
2,656 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 4TH Pass on G Code is way off on my CNC Machine
Page 1 of 2 12
Results 1 to 20 of 37
    Dec 2017
    53
    HI
    OH Dear!
    Luckily im just setting up, praticing and learning CNC
    Ive gotten so far but im stuck on this
    Highlighted in Pink was my 4th Pass using ASPIRE Then to G Code using Mach 3
    The 4th Pass went well off to the Left! and ruined my test peace!
    The 1,2 and 3rd passes all went okay highlighted in black
    Does any one know why the 4th pass decided to start off at a different position?
    many thanks, and appreciate any help given
    adam
    Dec 2017
    53
    Re: 4TH Pass on G Code is way off on my CNC Machine
    oh man
    Never had so much hassel attaching an image to a forum (chair)
    Nov 2014
    724
    Click on Go Advanced at the bottom of the text window and scroll down to Manage Attachments (or just click on the Paper Clip icon). From there browse to your photo(s). Hit the Paper Clip dropdown to insert the photo(s) where you want them in your text.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Dec 2017
    53
    attached is the image!!
    thanks too difalkner
    Jun 2005
    1730
    I would run the program again this time doing an air cut, no wood or anything. Single step the program and put a piece of paper on your machine and mark where the cutter moves. When u get to the forth pass you should see it move the machine in the wrong position. You can also run the gcode on a simulator which you can download for free and determine if the gcode is correct
    Russ
    Dec 2017
    53
    Thanks Russ(wedge)
    But running it again doesnt answer why it did this
    Anyone else have any ideas please?
    I will try some new G Codes etc
    But it would be handy too see why it did it in the first place
    adam
    Nov 2008
    643
    I would assume that the problem isn’t coming from Aspire. You can simulate the cut in Aspire.
    Two things would cause this from the machine. Stepper looses steps or stepper shaft not tight.
    Why those aren’t issues is they happen under load not between passes.
    So my guess is that Aspire is sending some code that your controller doesn’t understand
    I’d start removing lines of code and see what happens. Also try a simple shape like a square. Or code it by hand. Have fun, it’s a good way to learn.
    Dec 2017
    53
    Stepper looses steps or stepper shaft not tight.what is that? and how does it loose steps?
    My thoughts were
    It could be the way i saved the G-Code in Aspire? as there is sevral options
    It looses steps, but not sure how that happens
    Saying this i was hoping someone elese has had this happen to them before
    Today i will try more new shaps, and texts
    and will update
    But always handy to know 100% how it happened
    Thanks for the input guys , cheers
    May 2004
    210
    Start a process of elimination to find the problem. Use a gcode viewer to look at your code first. I use https://ncviewer.com/ but there are plenty to choose from. It will tell you if it is your machine or the gcode.
    Dec 2017
    53
    mmmmmmmmmmmmmmmmmmmmmmm
    Sadly happened again!
    I saved as G Code Mach 3
    and even on my first cut it went haywire!
    I then said lets try no G Code and a straight cut using my keyboard
    I pressed the arrow key firmly and it will move perfectly >>>>>>>>>>>>>>>> Then it just stopped!
    so tried a few times it will move using the keyboard arrow key so much then it just stops!
    This is making me think its hardware issues somewhere?:drowning::drowning:
    Dec 2017
    53
    The Y Axis in MACH3 Was ticked and the X wasnt! in DIR LOW Active
    i just unticked it, dont think that would of helped any as the X wasnt ticked
    May 2004
    210
    Calm down, these are simple machines. First off, you need to be methodical in your approach. Try jogging each axis in turn to see if that works OK. Does it stop in the same location? On the one(s) that fail, disconnect the motor and move it by hand to see if there is any binding. (that's my guess but you've presented zero info about your machine...) If it is a dual motor moving gantry, maybe it racks?
    But before anything else, make sure everything is tightened up. Even if it seems solid, even a small amount of slop can cause problems.
    Dec 2017
    53
    Dec 2017
    53
    Thats a great reply, thanks philba i had it working last year must be something simples
    But will try that now!
    Jun 2005
    1730
    This appears to be binding in your machine. You can so some simple gcode commands on your machines, such as follows:
    First home your machine, did it get home successfully?
    Now in your MDI entry, type
    G1 X5 F50 does it move to the right five inches?
    G1 Y5 F50 does it move in the Y direction five inches?
    With the machine powered down can you move the X and Y axis smoothly? You could have a loose coupler from the stepper motor to the ballscrew or leadscrew.
    Post a picture of your machine.
    Russ
    Dec 2017
    53
    Dec 2017
    53
    OH GOSH
    so
    Ive just tried
    A new postition on the CNC Table with a basic llines to be cut, 1st cut went okay then half way through the second cut it went way off and again and just stopped/paused!
    So i then
    Stopped the G Code and Closed the g code
    Then being safe i switched on the router and then
    Pressed the page UP To left the Z AXIS UP
    And guess what THE Z AXIS
    SPUN UP MEGA FAST! Faster than ever, dangerously fast until it was spinning round the shaft as couldnt go up higher, so i switched the hole thing off
    I wonder what it is? Im thinking its something to do with my NVUM USB Controller from CHINA?
    Dec 2017
    53
    Thanks everyone i really appreciate all your inputs, Thanks to each and everyone who is replying
    The smiling face on the Plywood was made last year and worked ok
    I have just moved all Axis by hand with the machine off, its a bit stiff but moves okay!
    Ive still to try the MIDI Entry
    Its weird how it cuts okay for the first 1-2 passes! then goes bad on me on the 2-3rd pass
    Thats why i think its not the actual Machine guides or Nemas etc as it makes the first line okay
    Im thinking its maybe
    How i save the G Code?
    The Chinese NVUM Cntroller via USB to my PC
    Possibly the G code itself but i doubt that!
    Then how did the Z Axis shot up so FAST Like suddenly speed up real fast hasnt done that before!
    Dangerous i want to get it fully working 100% make some things then sell it when i can confindetially sell it!
    Then i will build a newer smaller one for myself from scratch
    • Adam
    Dec 2017
    53
    better image of panel
    May 2004
    210
    Quote Originally Posted by CNCMAN172 View Post
    Agreed but I think our friend is all over the map. It probably is binding though it appears to be a low end Chinese machine so probably needs a full round of tightening and such. It may not have been assembled exactly to spec either.
    Adam: stop what you are doing and focus on one issue - binding. Try what Russ (and I) suggested. Try to figure out if each axis works correctly. Verify each axis in turn.
Page 1 of 2 12
  1. 3d cnc wood carving machine 1500*3000 4th Axis cnc 3d machine
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 07-03-2020, 11:07 AM
  2. How to delete a full pass in g-code
    By bivegele in forum Uncategorised WoodWorking Machines
    Last Post: 04-07-2020, 10:30 AM
  3. 4th axis cnc router machine BKM1325 from Baokun cnc company
    By Elissa in forum News Announcements
    Last Post: 07-24-2019, 09:15 AM
  4. Replies: 14
    Last Post: 07-19-2014, 05:55 AM
  5. g code - invert X axis after one pass...
    By dodman in forum G-Code Programing
    Last Post: 07-08-2013, 09:32 AM
