586,062 active members*
4,697 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 4TH Pass on G Code is way off on my CNC Machine
Page 1 of 2 12
Results 1 to 20 of 37
    Dec 2017
    53
    HI
    OH Dear!
    Luckily im just setting up, praticing and learning CNC
    Ive gotten so far but im stuck on this
    Highlighted in Pink was my 4th Pass using ASPIRE Then to G Code using Mach 3
    The 4th Pass went well off to the Left! and ruined my test peace!
    The 1,2 and 3rd passes all went okay highlighted in black
    Does any one know why the 4th pass decided to start off at a different position?
    many thanks, and appreciate any help given
    adam
    Dec 2017
    53
    Re: 4TH Pass on G Code is way off on my CNC Machine
    oh man
    Never had so much hassel attaching an image to a forum (chair)
    Dec 2017
    53
    Thanks one again guys, very much appreciated
    Okay a good update!
    I made the internal cabinet tidy
    I recall someone saying once that the Chinese controllers via USB can be temprimental and always better with CAT Style plug or the older style big parrell plugs
    So after i did that i made a new G Gode and sent that to the machne
    It cut it perfectly on 2 x passes
    But
    It was using Softcore board!
    So im not 100% but maybe its one of these three things!
    1: Dodgy interference via USB Cable but it is a sheilded cable im using! Interference from another source, or simply its cause its a USB out from controller to the PC
    2: The motors struggle on the 3rd pass on thicker wood! will require further testing though
    3: G Code issue?
    im still thinking 1,2 is the culprit
    The binding seems to happen and puts it off course, but this new cut was 100% but thats after i moved the NVUM controller to the rear of the enclosure and checked all the cables etc and it was only cutting softcore board not thicker dense ply
    Will update guys!
    the new okay cut!
    Nov 2014
    724
    Click on Go Advanced at the bottom of the text window and scroll down to Manage Attachments (or just click on the Paper Clip icon). From there browse to your photo(s). Hit the Paper Clip dropdown to insert the photo(s) where you want them in your text.
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Dec 2017
    53
    attached is the image!!
    thanks too difalkner
    Jun 2005
    1730
    I would run the program again this time doing an air cut, no wood or anything. Single step the program and put a piece of paper on your machine and mark where the cutter moves. When u get to the forth pass you should see it move the machine in the wrong position. You can also run the gcode on a simulator which you can download for free and determine if the gcode is correct
    Russ
    Dec 2017
    53
    Thanks Russ(wedge)
    But running it again doesnt answer why it did this
    Anyone else have any ideas please?
    I will try some new G Codes etc
    But it would be handy too see why it did it in the first place
    adam
    Dec 2017
    53
    Well this morning i made a quick sign and was very happy it done okay on two passes:
    However on my second cut this afternoon it went haywire again lol
    So not sure is it my G Code? or is it Interference? or is it dodgy nema 23 not having the stregth to pull over the wood, i think not as it seems to
    Just go way off what i want it to do!
    so what you guys rekon?
    Is it my dodgy G Code? maybe im saving it wrong ??? as there is a lot off different options to save as?
    Or is it interference? bad connection etc
    what it looks like on aspre
    what it looks li
    ke when it was cutting
    Nov 2008
    643
    I would assume that the problem isn’t coming from Aspire. You can simulate the cut in Aspire.
    Two things would cause this from the machine. Stepper looses steps or stepper shaft not tight.
    Why those aren’t issues is they happen under load not between passes.
    So my guess is that Aspire is sending some code that your controller doesn’t understand
    I’d start removing lines of code and see what happens. Also try a simple shape like a square. Or code it by hand. Have fun, it’s a good way to learn.
    Dec 2017
    53
    Stepper looses steps or stepper shaft not tight.what is that? and how does it loose steps?
    My thoughts were
    It could be the way i saved the G-Code in Aspire? as there is sevral options
    It looses steps, but not sure how that happens
    Saying this i was hoping someone elese has had this happen to them before
    Today i will try more new shaps, and texts
    and will update
    But always handy to know 100% how it happened
    Thanks for the input guys , cheers
    May 2004
    210
    Start a process of elimination to find the problem. Use a gcode viewer to look at your code first. I use https://ncviewer.com/ but there are plenty to choose from. It will tell you if it is your machine or the gcode.
    Dec 2017
    53
    mmmmmmmmmmmmmmmmmmmmmmm
    Sadly happened again!
    I saved as G Code Mach 3
    and even on my first cut it went haywire!
    I then said lets try no G Code and a straight cut using my keyboard
    I pressed the arrow key firmly and it will move perfectly >>>>>>>>>>>>>>>> Then it just stopped!
    so tried a few times it will move using the keyboard arrow key so much then it just stops!
    This is making me think its hardware issues somewhere?:drowning::drowning:
    Dec 2017
    53
    MMMMMMMMMMM
    Could also be the Windows 7 PC
    As the Wireless Mouse and Keyboard dont work 90% of the time, PITA now
    Im going to try this on another PC soon! (chair)
    Dec 2017
    53
    The Y Axis in MACH3 Was ticked and the X wasnt! in DIR LOW Active
    i just unticked it, dont think that would of helped any as the X wasnt ticked
    May 2004
    210
    Calm down, these are simple machines. First off, you need to be methodical in your approach. Try jogging each axis in turn to see if that works OK. Does it stop in the same location? On the one(s) that fail, disconnect the motor and move it by hand to see if there is any binding. (that's my guess but you've presented zero info about your machine...) If it is a dual motor moving gantry, maybe it racks?
    But before anything else, make sure everything is tightened up. Even if it seems solid, even a small amount of slop can cause problems.
    Dec 2017
    53
    Thats a great reply, thanks philba i had it working last year must be something simples
    But will try that now!
    Dec 2017
    53
    I THINK!!!!!!!!!!!!!!!!
    Ive just made a major discovery!
    When switched the X Axis and the Z Axis is SOLID! When you Push or Pull these two axis it doesnt move!
    The Y Axis Moves manually Easily bby about 1cm back and forth! Now that must be the issue?
    Somewhere somewhow the Y Axis is moving freely by about 1cm before being the same as the X and Z
    So it has to be something to do with my Y Axis
    Im not sure now if its mechanical or its a fault in the motor etc, But i think its been established that its a mechanical fault somewhere on the Y axis
    wherever its the belt, bolts, nuts or nema 23 issue!
    Y AXIS I think is the culprit
    Working on that now!
    Dec 2017
    53
    Dec 2017
    53
    FFS!
    Its happening still
    I just installed a new motion controller
    ZKMotion Mach3 4 Axis USB CNC Motion Card
    And now my drivers use 4 x wires insted of 3 before
    Still im getting cocked up signs lol
    I sit Motor tuning? this is something im still working on guys!
    with the new controller! Seems to do its own thing and doesnt follow the sip[le GCode as attached
    any ideas guys
    T1M6
    G17
    G0Z20.000
    G0X0.000Y0.000S12000M3
    G0X-45.428Y6.621Z6.000
    G1Z-3.000F762.0
    G1X-45.832Y6.170F2540.0
    X-45.428Y5.720
    X-45.023Y6.170
    X-45.428Y6.621
    G0Z6.000
    G0X-41.040Y-12.196
    G1Z-3.000F762.0
    G1X-41.673Y-12.342F2540.0
    X-42.079Y-12.379
    X-42.415Y-12.367
    X-42.717Y-12.331
    X-43.013Y-12.269
    X-43.301Y-12.179
    X-43.579Y-12.062
    X-43.843Y-11.916
    X-44.091Y-11.743
    X-44.332Y-11.534
    X-44.563Y-11.269
    X-44.757Y-10.960
    X-44.907Y-10.630
    X-45.020Y-10.284
    X-45.101Y-9.921
    X-45.156Y-9.539
    X-45.188Y-9.137
    X-45.198Y5.022
    X-45.187Y5.167
    X-45.154Y5.316
    X-45.095Y5.464
    X-45.012Y5.604
    X-44.905Y5.730
    X-44.779Y5.836
    X-44.639Y5.920
    X-44.492Y5.978
    X-44.343Y6.012
    X-44.198Y6.022
    X-40.034Y6.031
    X-39.962Y6.068
    X-39.962Y6.168
    X-40.074Y6.301
    X-40.150Y6.318
    X-44.198
    X-44.343Y6.329
    X-44.492Y6.363
    X-44.639Y6.421
    X-44.779Y6.505
    X-44.905Y6.611
    X-45.012Y6.737
    X-45.095Y6.877
    X-45.154Y7.025
    X-45.187Y7.174
    X-45.198Y7.318
    X-45.208Y11.945
    X-45.257Y12.040
    X-45.353Y12.089
    X-45.503
    X-45.599Y12.040
    X-45.648Y11.945
    X-45.658Y7.318
    X-45.668Y7.174
    X-45.702Y7.025
    X-45.760Y6.877
    X-45.844Y6.737
    X-45.951Y6.611
    X-46.077Y6.505
    X-46.217Y6.421
    X-46.364Y6.363
    X-46.513Y6.329
    X-46.658Y6.318
    X-49.708Y6.310
    X-49.801Y6.261
    X-49.832Y6.213
    X-49.822Y6.104
    X-49.741Y6.040
    X-49.608Y6.022
    X-46.658
    X-46.513Y6.012
    X-46.364Y5.978
    X-46.217Y5.920
    X-46.077Y5.836
    X-45.951Y5.730
    X-45.844Y5.604
    X-45.760Y5.464
    X-45.702Y5.316
    X-45.668Y5.167
    X-45.658Y5.022
    Y-8.824
    X-45.646Y-9.332
    X-45.613Y-9.783
    X-45.559Y-10.188
    X-45.486Y-10.545
    X-45.397Y-10.853
    X-45.296Y-11.114
    X-45.185Y-11.327
    X-45.058Y-11.515
    X-44.746Y-11.871
    X-44.449Y-12.131
    X-44.189Y-12.290
    X-43.956Y-12.374
    X-43.587Y-12.448
    X-43.171Y-12.504
    X-42.718Y-12.539
    X-42.246Y-12.550
    X-41.911Y-12.531
    X-41.634Y-12.481
    X-41.394Y-12.403
    X-41.104Y-12.249
    X-41.012Y-12.180Z-2.991
    X-40.930Y-12.202Z-2.912
    X-40.922Y-11.983Z-2.806
    X-40.919Y-11.973Z-2.796
    X-41.003Y-12.169Z-2.982
    X-41.040Y-12.196Z-3.000
    G0Z6.000
    G0X-34.306Y-1.734
    G1Z-3.000F762.0
    G1X-34.324Y-1.972F2540.0
    X-34.182Y-1.867
    X-34.306Y-1.734
    G0Z6.000
    G0X-25.108Y6.827
    G1Z-3.000F762.0
    G1X-25.648Y6.876F2540.0
    X-26.197Y6.892
    X-26.752Y6.873
    X-27.295Y6.818
    X-27.830Y6.726
    X-28.356Y6.596
    X-28.875Y6.430
    X-29.388Y6.226
    X-29.896Y5.984
    X-30.396Y5.704
    X-30.878Y5.390
    X-31.333Y5.045
    X-31.764Y4.666
    X-32.171Y4.253
    X-32.556Y3.804
    X-32.919Y3.319
    X-33.259Y2.798
    X-33.575Y2.241
    X-33.858Y1.656
    X-34.104Y1.049
    X-34.312Y0.415
    X-34.484Y-0.247
    X-34.618Y-0.936
    X-34.715Y-1.655
    X-34.773Y-2.402
    X-34.793Y-3.177
    X-34.773Y-3.910
    X-34.714Y-4.617
    X-34.617Y-5.297
    X-34.482Y-5.952
    X-34.309Y-6.582
    X-34.098Y-7.187
    X-33.850Y-7.770
    X-33.564Y-8.330
    X-33.244Y-8.865
    X-32.895Y-9.368
    X-32.518Y-9.838
    X-32.111Y-10.277
    X-31.675Y-10.686
    X-31.208Y-11.064
    X-30.710Y-11.414
    X-30.180Y-11.734
    X-29.625Y-12.020
    X-29.049Y-12.267
    X-28.450Y-12.477
    X-27.828Y-12.650
    X-27.182Y-12.785
    X-26.511Y-12.882
    X-25.814Y-12.940
    X-25.093Y-12.960
    X-24.601Y-12.946
    X-24.117Y-12.903
    X-23.641Y-12.832
    X-23.171Y-12.732
    X-22.708Y-12.604
    X-22.250Y-12.447
    X-21.796Y-12.262
    X-21.345Y-12.045
    X-20.902Y-11.804
    X-20.478Y-11.546
    X-20.075Y-11.272
    X-19.693Y-10.984
    X-19.331Y-10.680
    X-18.988Y-10.362
    X-18.666Y-10.027
    X-18.191Y-9.462
    X-18.188Y-9.455
    X-18.131Y-9.446Z-2.947
    X-18.188Y-9.455Z-3.000
    X-18.250Y-9.393
    X-18.242Y-9.340Z-2.950
    X-18.250Y-9.393Z-3.000
    X-18.407Y-9.482
    X-18.585Y-9.707
    X-18.889Y-10.049
    X-19.215Y-10.373
    X-19.561Y-10.679
    X-19.927Y-10.968
    X-20.313Y-11.239
    X-20.717Y-11.493
    X-21.145Y-11.732
    X-21.595Y-11.950
    X-22.064Y-12.141
    X-22.546Y-12.303
    X-23.041Y-12.434
    X-23.547Y-12.535
    X-24.065Y-12.608
    X-24.594Y-12.651
    X-25.134Y-12.665
    X-25.816Y-12.646
    X-26.480Y-12.587
    X-27.126Y-12.490
    X-27.754Y-12.352
    X-28.362Y-12.173
    X-28.950Y-11.954
    X-29.515Y-11.694
    X-30.056Y-11.394
    X-30.567Y-11.062
    X-31.048Y-10.700
    X-31.500Y-10.309
    X-31.922Y-9.887
    X-32.314Y-9.437
    X-32.674Y-8.958
    X-33.003Y-8.453
    X-33.299Y-7.921
    X-33.563Y-7.368
    X-33.790Y-6.798
    X-33.982Y-6.211
    X-34.139Y-5.609
    X-34.260Y-4.992
    X-34.347Y-4.360
    X-34.398Y-3.714
    X-34.415Y-3.080
    X-34.409Y-2.947
    X-34.384Y-2.809
    X-34.338Y-2.671
    X-34.271Y-2.537
    X-34.182Y-2.413
    X-34.076Y-2.304
    X-33.954Y-2.212
    X-33.822Y-2.141
    X-33.685Y-2.092
    X-33.548Y-2.063
    X-33.415Y-2.054
    X-17.867Y-2.046
    X-17.747Y-1.978
    X-17.695Y-1.901
    X-17.716Y-1.190
    X-17.781Y-0.530
    X-17.884Y0.102
    X-18.023Y0.706
    X-18.198Y1.283
    X-18.408Y1.834
    X-18.653Y2.359
    X-18.937Y2.864
    X-19.252Y3.346
    X-19.590Y3.799
    X-19.948Y4.219
    X-20.326Y4.608
    X-20.726Y4.966
    X-21.147Y5.294
    X-21.591Y5.592
    X-22.059Y5.863
    X-22.546Y6.104
    X-23.042Y6.313
    X-23.546Y6.490
    X-24.057Y6.635
    X-24.578Y6.747
    X-25.108Y6.827
    G0Z6.000
    G0X-24.364Y6.311
    G1Z-3.000F762.0
    G1X-23.915Y6.196F2540.0
    X-23.471Y6.057
    X-23.032Y5.892
    X-22.596Y5.703
    X-22.168Y5.487
    X-21.754Y5.245
    X-21.358Y4.980
    X-20.980Y4.691
    X-20.620Y4.378
    X-20.279Y4.042
    X-19.958Y3.684
    X-19.656Y3.302
    X-19.374Y2.897
    X-19.121Y2.472
    X-18.897Y2.030
    X-18.704Y1.572
    X-18.542Y1.099
    X-18.409Y0.612
    X-18.307Y0.111
    X-18.229Y-0.442
    Y-0.840
    X-18.239Y-0.985
    X-18.273Y-1.134
    X-18.332Y-1.282
    X-18.415Y-1.422
    X-18.522Y-1.548
    X-18.648Y-1.654
    X-18.788Y-1.738
    X-18.935Y-1.796
    X-19.084Y-1.830
    X-19.229Y-1.840
    X-33.210
    X-33.344Y-1.832
    X-33.482Y-1.803
    X-33.621Y-1.752
    X-33.756Y-1.678
    X-33.881Y-1.582
    X-33.990Y-1.466
    X-34.080Y-1.334
    X-34.146Y-1.191
    X-34.189Y-1.044
    X-34.208Y-0.897
    X-34.206Y-0.755
    X-34.186Y-0.623
    X-34.012Y0.159
    X-33.778Y0.935
    X-33.494Y1.659
    X-33.148Y2.359
    X-32.750Y3.006
    X-32.299Y3.605
    X-31.793Y4.155
    X-31.231Y4.656
    X-30.663Y5.082
    X-30.072Y5.458
    X-29.464Y5.778
    X-28.839Y6.043
    X-28.198Y6.249
    X-27.543Y6.397
    X-26.876Y6.486
    X-26.207Y6.515
    X-25.735Y6.502
    X-25.275Y6.464
    X-24.818Y6.400
    X-24.364Y6.311
    G0Z6.000
    G0X0.574Y-5.863
    G1Z-3.000F762.0
    G1X0.836Y-6.289F2540.0
    X1.039Y-6.749
    X1.180Y-7.234
    X1.262Y-7.739
    X1.288Y-8.263
    X1.260Y-8.800
    X1.171Y-9.320
    X1.020Y-9.820
    X0.804Y-10.292
    X0.526Y-10.730
    X0.191Y-11.128
    X-0.197Y-11.482
    X-0.625Y-11.788
    X-1.071Y-12.047
    X-1.528Y-12.268
    X-2.001Y-12.454
    X-2.491Y-12.605
    X-2.996Y-12.722
    X-3.515Y-12.805
    X-4.047Y-12.854
    X-4.590Y-12.870
    X-5.139Y-12.856
    X-5.676Y-12.814
    X-6.202Y-12.745
    X-6.717Y-12.646
    X-7.221Y-12.519
    X-7.712Y-12.364
    X-8.190Y-12.179
    X-8.655Y-11.966
    X-9.106Y-11.724
    X-9.542Y-11.454
    X-9.963Y-11.157
    X-10.368Y-10.833
    X-10.757Y-10.482
    X-11.129Y-10.105
    X-11.486Y-9.702
    X-11.751Y-9.370
    X-11.873Y-9.280
    X-11.935Y-9.267
    X-11.976Y-9.158Z-2.890
    X-11.935Y-9.267Z-3.000
    X-12.100Y-9.381
    X-12.283Y-9.308Z-2.834
    X-12.100Y-9.381Z-3.000
    X-11.965Y-9.660
    X-11.664Y-10.020
    X-11.309Y-10.403
    X-10.940Y-10.757
    X-10.559Y-11.083
    X-10.166Y-11.383
    X-9.758Y-11.655
    X-9.338Y-11.902
    X-8.903Y-12.122
    X-8.453Y-12.317
    X-7.987Y-12.486
    X-7.505Y-12.630
    X-7.007Y-12.748
    X-6.492Y-12.840
    X-5.958Y-12.907
    X-5.407Y-12.947
    X-4.842Y-12.960
    X-4.130Y-12.937
    X-3.459Y-12.870
    X-2.824Y-12.760
    X-2.224Y-12.607
    X-1.658Y-12.412
    X-1.124Y-12.176
    X-0.620Y-11.898
    X-0.137Y-11.572
    X0.274Y-11.234
    X0.627Y-10.871
    X0.919Y-10.488
    X1.156Y-10.083
    X1.340Y-9.650
    X1.473Y-9.185
    X1.555Y-8.683
    X1.583Y-8.140
    X1.571Y-7.718
    X1.535Y-7.327
    X1.477Y-6.966
    X1.399Y-6.635
    X1.301Y-6.332
    X1.184Y-6.057
    X1.050Y-5.806
    X0.892Y-5.570
    X0.506Y-5.112
    X0.062Y-4.703
    X-0.439Y-4.347
    X-0.998Y-4.043
    X-1.687Y-3.746
    X-2.473Y-3.459
    X-3.359Y-3.182
    X-5.034Y-2.734
    X-6.293Y-2.349
    X-6.865Y-2.146
    X-7.399Y-1.935
    X-7.897Y-1.715
    X-8.358Y-1.485
    X-8.791Y-1.239
    X-9.205Y-0.956
    X-9.586Y-0.626
    X-9.920Y-0.257
    X-10.203Y0.152
    X-10.429Y0.593
    X-10.596Y1.063
    X-10.705Y1.553
    X-10.761Y2.084
    X-10.733Y2.651
    X-10.651Y3.171
    X-10.510Y3.671
    X-10.308Y4.144
    X-10.046Y4.584
    X-9.726Y4.986
    X-9.354Y5.343
    X-8.942Y5.649
    X-8.513Y5.907
    X-8.072Y6.126
    X-7.613Y6.310
    X-7.137Y6.459
    X-6.645Y6.574
    X-6.139Y6.656
    X-5.618Y6.704
    X-5.087Y6.720
    X-4.651Y6.710
    X-4.223Y6.679
    X-3.800Y6.629
    X-3.384Y6.557
    X-2.973Y6.466
    X-2.569Y6.353
    X-2.172Y6.220
    X-1.782Y6.066
    X-1.400Y5.892
    X-1.030Y5.698
    X-0.673Y5.484
    X-0.328Y5.250
    X0.003Y4.998
    X0.320Y4.727
    X0.623Y4.437
    X0.918Y4.140
    X0.987Y4.149
    X1.000Y4.127Z-2.976
    X0.987Y4.149Z-3.000
    X1.042Y4.224
    X1.042Y4.290
    X1.068Y4.302Z-2.972
    X1.042Y4.290Z-3.000
    X0.637Y4.723
    X0.339Y5.012
    X0.029Y5.278
    X-0.294Y5.522
    X-0.631Y5.743
    X-0.982Y5.944
    X-1.348Y6.123
    X-1.733Y6.282
    X-2.538Y6.550
    X-3.339Y6.741
    X-4.132Y6.854
    X-4.921Y6.892
    X-5.379Y6.882
    X-5.823Y6.851
    X-6.252Y6.799
    X-6.665Y6.727
    X-7.063Y6.636
    X-7.447Y6.525
    X-7.818Y6.394
    X-8.175Y6.244
    X-8.515Y6.077
    X-8.835Y5.895
    X-9.133Y5.699
    X-9.411Y5.490
    X-9.669Y5.266
    X-9.909Y5.028
    X-10.131Y4.775
    X-10.334Y4.507
    X-10.515Y4.231
    X-10.669Y3.950
    X-10.798Y3.662
    X-10.904Y3.365
    X-10.987Y3.059
    X-11.046Y2.742
    X-11.082Y2.413
    X-11.088Y1.789
    X-11.038Y1.264
    X-10.940Y0.789
    X-10.798Y0.359
    X-10.612Y-0.031
    X-10.382Y-0.385
    X-10.104Y-0.711
    X-9.774Y-1.012
    X-9.589Y-1.152
    X-9.135Y-1.454
    X-8.635Y-1.744
    X-8.084Y-2.023
    X-7.485Y-2.291
    X-6.835Y-2.547
    X-6.137Y-2.789
    X-5.389Y-3.018
    X-3.978Y-3.398
    X-2.843Y-3.755
    X-2.321Y-3.948
    X-1.828Y-4.152
    X-1.366Y-4.367
    X-0.932Y-4.594
    X-0.517Y-4.842
    X-0.113Y-5.133
    X0.256Y-5.476
    X0.574Y-5.863
    G0Z6.000
    G0X10.496Y5.720
    G1Z-3.000F762.0
    G1X10.900Y6.170F2540.0
    X10.496Y6.621
    X10.092Y6.170
    X10.496Y5.720
    G0Z6.000
    G0X14.884Y-12.196
    G1Z-3.000F762.0
    G1X14.251Y-12.342F2540.0
    X13.844Y-12.379
    X13.509Y-12.367
    X13.207Y-12.331
    X12.911Y-12.269
    X12.622Y-12.179
    X12.345Y-12.062
    X12.080Y-11.916
    X11.833Y-11.743
    X11.592Y-11.534
    X11.361Y-11.269
    X11.166Y-10.960
    X11.017Y-10.630
    X10.904Y-10.284
    X10.822Y-9.921
    X10.767Y-9.539
    X10.736Y-9.137
    X10.726Y5.022
    X10.737Y5.167
    X10.770Y5.316
    X10.829Y5.464
    X10.912Y5.604
    X11.019Y5.730
    X11.145Y5.836
    X11.285Y5.920
    X11.432Y5.978
    X11.581Y6.012
    X11.726Y6.022
    X15.890Y6.031
    X15.962Y6.068
    X15.961Y6.168
    X15.850Y6.301
    X15.773Y6.318
    X11.726
    X11.581Y6.329
    X11.432Y6.363
    X11.285Y6.421
    X11.145Y6.505
    X11.019Y6.611
    X10.912Y6.737
    X10.829Y6.877
    X10.770Y7.025
    X10.737Y7.174
    X10.726Y7.318
    X10.716Y11.945
    X10.667Y12.040
    X10.571Y12.089
    X10.421
    X10.325Y12.040
    X10.276Y11.945
    X10.266Y7.318
    X10.255Y7.174
    X10.222Y7.025
    X10.163Y6.877
    X10.080Y6.737
    X9.973Y6.611
    X9.847Y6.505
    X9.707Y6.421
    X9.560Y6.363
    X9.411Y6.329
    X9.266Y6.318
    X6.216Y6.310
    X6.123Y6.261
    X6.092Y6.213
    X6.102Y6.104
    X6.183Y6.040
    X6.316Y6.022
    X9.266
    X9.411Y6.012
    X9.560Y5.978
    X9.707Y5.920
    X9.847Y5.836
    X9.973Y5.730
    X10.080Y5.604
    X10.163Y5.464
    X10.222Y5.316
    X10.255Y5.167
    X10.266Y5.022
    Y-8.824
    X10.278Y-9.332
    X10.311Y-9.783
    X10.365Y-10.188
    X10.438Y-10.545
    X10.527Y-10.853
    X10.628Y-11.114
    X10.739Y-11.327
    X10.866Y-11.515
    X11.178Y-11.871
    X11.475Y-12.131
    X11.735Y-12.290
    X11.968Y-12.374
    X12.337Y-12.448
    X12.753Y-12.504
    X13.206Y-12.539
    X13.678Y-12.550
    X14.012Y-12.531
    X14.290Y-12.481
    X14.530Y-12.403
    X14.820Y-12.249
    X14.912Y-12.180Z-2.991
    X14.993Y-12.202Z-2.912
    X15.002Y-11.983Z-2.806
    X15.004Y-11.973Z-2.796
    X14.920Y-12.169Z-2.982
    X14.884Y-12.196Z-3.000
    G0Z6.000
    G0X33.866Y11.933
    G1Z-3.000F762.0
    G1X34.123Y11.960F2540.0
    X34.123Y12.527
    X33.908Y12.544
    X33.710Y12.531
    X33.561Y12.500
    X33.568Y11.968
    X33.673Y11.945
    X33.866Y11.933
    G0Z6.000
    G0X34.086Y6.615
    G1Z-3.000F762.0
    G1X34.037Y6.710F2540.0
    X33.941Y6.759
    X33.791
    X33.695Y6.710
    X33.646Y6.615
    X33.636Y6.497
    X33.646Y-12.396
    X33.695Y-12.491
    X33.791Y-12.540
    X33.941
    X34.037Y-12.491
    X34.086Y-12.396
    X34.096Y-12.278
    X34.086Y6.615
    G0Z6.000
    G0X33.163Y11.837
    G1Z-3.000F762.0
    G1X33.215Y11.702F2540.0
    X33.318Y11.617
    X33.413Y11.578
    X33.616Y11.534
    X33.866Y11.518
    X34.113Y11.534
    X34.348Y11.591
    X34.461Y11.666
    X34.519Y11.787
    X34.547Y12.072
    Y12.407
    X34.518Y12.715
    X34.456Y12.846
    X34.349Y12.902
    X34.155Y12.943
    X33.907Y12.959
    X33.654Y12.943
    X33.394Y12.880
    X33.231Y12.777
    X33.171Y12.667
    X33.144Y12.423
    Y12.074
    X33.163Y11.837
    G0Z6.000
    G0X44.362Y5.720
    G1Z-3.000F762.0
    G1X44.766Y6.170F2540.0
    X44.362Y6.621
    X43.957Y6.170
    X44.362Y5.720
    G0Z6.000
    G0X48.750Y-12.196
    G1Z-3.000F762.0
    G1X48.117Y-12.342F2540.0
    X47.710Y-12.379
    X47.375Y-12.367
    X47.073Y-12.331
    X46.777Y-12.269
    X46.488Y-12.179
    X46.210Y-12.062
    X45.946Y-11.916
    X45.699Y-11.743
    X45.458Y-11.534
    X45.226Y-11.269
    X45.032Y-10.960
    X44.882Y-10.630
    X44.770Y-10.284
    X44.688Y-9.921
    X44.633Y-9.539
    X44.602Y-9.137
    X44.592Y5.022
    X44.602Y5.167
    X44.636Y5.316
    X44.694Y5.464
    X44.778Y5.604
    X44.885Y5.730
    X45.011Y5.836
    X45.151Y5.920
    X45.298Y5.978
    X45.447Y6.012
    X45.592Y6.022
    X49.756Y6.031
    X49.828Y6.068
    X49.827Y6.168
    X49.716Y6.301
    X49.639Y6.318
    X45.592
    X45.447Y6.329
    X45.298Y6.363
    X45.151Y6.421
    X45.011Y6.505
    X44.885Y6.611
    X44.778Y6.737
    X44.694Y6.877
    X44.636Y7.025
    X44.602Y7.174
    X44.592Y7.318
    X44.582Y11.945
    X44.533Y12.040
    X44.437Y12.089
    X44.287
    X44.191Y12.040
    X44.142Y11.945
    X44.132Y7.318
    X44.121Y7.174
    X44.088Y7.025
    X44.029Y6.877
    X43.946Y6.737
    X43.839Y6.611
    X43.713Y6.505
    X43.573Y6.421
    X43.426Y6.363
    X43.277Y6.329
    X43.132Y6.318
    X40.082Y6.310
    X39.989Y6.261
    X39.958Y6.213
    X39.968Y6.104
    X40.048Y6.040
    X40.182Y6.022
    X43.132
    X43.277Y6.012
    X43.426Y5.978
    X43.573Y5.920
    X43.713Y5.836
    X43.839Y5.730
    X43.946Y5.604
    X44.029Y5.464
    X44.088Y5.316
    X44.121Y5.167
    X44.132Y5.022
    Y-8.824
    X44.143Y-9.332
    X44.177Y-9.783
    X44.231Y-10.188
    X44.304Y-10.545
    X44.392Y-10.853
    X44.494Y-11.114
    X44.605Y-11.327
    X44.732Y-11.515
    X45.044Y-11.871
    X45.341Y-12.131
    X45.601Y-12.290
    X45.834Y-12.374
    X46.203Y-12.448
    X46.619Y-12.504
    X47.071Y-12.539
    X47.544Y-12.550
    X47.878Y-12.531
    X48.156Y-12.481
    X48.395Y-12.403
    X48.686Y-12.249
    X48.778Y-12.180Z-2.991
    X48.859Y-12.202Z-2.912
    X48.868Y-11.983Z-2.806
    X48.870Y-11.973Z-2.796
    X48.786Y-12.169Z-2.982
    X48.750Y-12.196Z-3.000
    G0Z6.000
    G0Z20.000
    G0X0.000Y0.000
    M30
    Jun 2005
    1730
    This appears to be binding in your machine. You can so some simple gcode commands on your machines, such as follows:
    First home your machine, did it get home successfully?
    Now in your MDI entry, type
    G1 X5 F50 does it move to the right five inches?
    G1 Y5 F50 does it move in the Y direction five inches?
    With the machine powered down can you move the X and Y axis smoothly? You could have a loose coupler from the stepper motor to the ballscrew or leadscrew.
    Post a picture of your machine.
    Russ
Page 1 of 2 12
  1. 3d cnc wood carving machine 1500*3000 4th Axis cnc 3d machine
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 07-03-2020, 11:07 AM
  2. How to delete a full pass in g-code
    By bivegele in forum Uncategorised WoodWorking Machines
    Last Post: 04-07-2020, 10:30 AM
  3. 4th axis cnc router machine BKM1325 from Baokun cnc company
    By Elissa in forum News Announcements
    Last Post: 07-24-2019, 09:15 AM
  4. Replies: 14
    Last Post: 07-19-2014, 05:55 AM
  5. g code - invert X axis after one pass...
    By dodman in forum G-Code Programing
    Last Post: 07-08-2013, 09:32 AM
