586,067 active members*
5,287 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > I NEED HELP TO RUN A DAEWOO PUMA 10HC
    Mar 2021
    22
    Unhappy I NEED HELP TO RUN A DAEWOO PUMA 10HC
    Hi friends I have a big problem because I got a 911 ram parity and my lathe did not bring any documentation, is there a charitable soul that can pass me the parameters of a puma 10hc or an 8hc? And if I happened to have the pmc diagnostic ladder it would be of great help, thank you.
    Feb 2013
    788
    Re: I NEED HELP TO RUN A DAEWOO PUMA 10HC
    What is the control model?
    What is the serial number?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Mar 2021
    22
    Hi dhardt I do not know exactly what type of control it is but here I leave you the photo of the information screen that appears at the beginning when the control is turned on, the funny thing is that where it says PMC only B2 appears at the end it is as if something was missing from the control or something It was damaged on a plate, the case is that it may be because of what I can not see anywhere the screen (SV-PRM) does not appear on the screen, could it be because it is an older model?, the case is that I have already achieved at least to be able to move the axles but it is rare all the daewoo puma of this year more or less all have this operational screen, thank you very much.
    https://imgur.com/969Qg8P
    https://imgur.com/YTkXS3L
    https://imgur.com/GpLXUdQ
