Hello all. I ahve posted before about this machine control (Hitachi Seiki Hitec Turn 20 w/Fanuc 10TF). Most recently I posted trying to figure out what kind of fuses I had that were blown and needed replacing. That issue has been resolved and the fuses are replaced.
So the next problem has now croped up. The control does not seem to fully power up now after replacing the fuses. Upon pressing the green control Power On button I get the following result:
The hydraulic motor seems to come on, the familiar relay clicks and clunks all seem to occur in the cabinets and things light up, all as normal/before the fuse blow. The CRT lights up/comes on, but does not display anything. This behavior is different. The machine functioned completely before the fuse blow. Pressing the Standby button has no effect on anything. Before more relay engagements would be heard and maybe some more fans would come on.\
Looking at the PCB (not sure correct name for it - master, etc.) with the 7 segment LED on it also shows a different behavior. Prior to the fure problem it would display a couple of numbers (don't remeber what numbers) and stop with I beleive 1 displayed. Now it simply displays A (at least I think that is what it is, all segements are lit except for the bottom most)
Does any one have any idea how to proceed from here? Is there even a way to proceed? I wonder is some alarm has to be reset/cleared before the control will fully power back up. But for all I know this could indicate some components are fried.
The fuse blow occured when someone was testing the function of the spindle overide knob. We suspect that a short occured in the contacts behind the knob.
Any help/advice is greatly appreciated. Have a great evening.
Best Wishes,
Rob
