586,089 active members*
3,870 visitors online*
Results 1 to 2 of 2
    Metal milling machine 600x400x500 with ATC
    Hello,
    ...likes, dislikes? What is wrong?
    Steel prefabricated construction, All milled and ground in one clamping. Dimensions 2m height, 2m width, 1.6m depth. Working space 600x400x500mm, feed 45m/min, electric spindle ISO30 7,5kW 18000rpm. Rotary headstock with the possibility of surface grinding. Weight 1.6t.
    Please comments, questions, criticism
    Thanks Marian from the Czech Republic (Prague)
    Apr 2004
    5737
    Re: Metal milling machine 600x400x500 with ATC
    It's hard to believe that little motor running in direct-drive mode is going to be able to slow down much or give you enough torque to mill metals effectively. Or is this primarily intended to be an engraving machine?
    Andrew Werby
    Website
  1. Metal milling machine 600x400x500 with ATC
    By mrosconi in forum Benchtop Machines
    Last Post: 05-29-2021, 06:21 AM
  2. Metal milling machine
    By moadi in forum Want To Buy...Need help!
    Last Post: 01-21-2019, 10:11 PM
  3. Light metal milling machine
    By khoac3 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-29-2016, 08:15 AM
  4. Metal CNC Milling Machine
    By endlasuresh in forum Benchtop Machines
    Last Post: 04-26-2016, 03:39 AM
  5. metal milling machine conversion
    By i-make-robots in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2011, 08:57 AM
