Re: FANUC Motor pulse generator question
By pulse generator, I assume you mean encoder?
Pulse generators are generally the term used for them in hand-wheels.
That appears to be a standard quadrature encoder, not the typical Fanuc encoder used in the servo's as these have a proprietary commutation method.
You most likely can use it where you would any other quadrature encoder.
Albert E.
