586,075 active members*
3,749 visitors online*
    Dec 2008
    51
    NEED HELP QT-15 w/T-2 control won't play
    Some Mondays are worse than others.
    My QT-15 with T-2 control decided it wanted to ruin my Monday by alarming out with all sorts of error codes , some I've never seen before.
    Here's a list:
    6- servo oscillation Z
    7- servo oscillation C
    9- detecting no signal X
    11- detecting no signal C
    20- NMI E-stop
    101- stored stroke limit +X
    104- stored stroke limit -Z
    117- chuck barrier
    179- home return error
    999- ??
    Machine was working fine last week.
    I have some spare PCBs and tried swapping out what I had to see if a board was bad, but that didn't help.
    Contacted Mitsubishi tech support and they asked if I was seeing asterisks in any of my parameters: answer-NO, only zeros or numerical values.
    So they're suggesting I may have an I/O board issue (they didn't say which board that is) or that my parameters got corrupted somehow and I should try backing up the control ? and reinitializing.
    I have several factory print outs on how to do the reintializing etc. as well copies of my parameters. But I'd sure like to know which board they are calling the I/O board.
    Has anyone run into this raft of alarms before ?
    I can understand the X and Z references, but "C" not so sure about.
    I've been in the back of this machine before, so am familiar with it's layout.
    Hoping someone can give me advice on this.
    Thanks in advance.
    Apr 2006
    111
    Re: NEED HELP QT-15 w/T-2 control won't play
    Check 24v power supply.
    Upload picture of led light in pcb of T-2
  1. Fanuc T10 Control won't operate at all
    By Scott Pancheau in forum Fanuc
    Last Post: 12-11-2020, 02:58 AM
  2. Laser won't turn off always on and no power control
    By jpnm24 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2020, 11:36 AM
  3. Z axis won't move under program control
    By Mike4703 in forum Mach Mill
    Last Post: 04-20-2020, 11:19 AM
  4. 4020 Cnc88hs Control won't boot
    By lmg in forum Fadal
    Last Post: 02-27-2013, 09:29 PM
  5. MX2 Control won't boot
    By beezerlm in forum Mori Seiki Mills
    Last Post: 02-17-2011, 09:37 PM
