586,058 active members*
3,687 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Need help with error 144 on delta 20 control
    Oct 2007
    6
    I'm going a bit nuts--using the solidworks cam system and post processor on a delta 20 control. It has it's glitches but in general, they're easily correctible. Unfortunately, I'm mostly an ignorant newbie when it comes to the more complex stuff. Most of what I do is really simple.
    But one is driving me a bit crazy and has me waaaay behind on something I need to get done ASAP
    Fault 144 CDC: Cutter R > circle R
    It's happening on a linear move and the manual is ZERO help in explaining the details of that particular fault on a linear move other than saying it applies. The whole program graphs on the machine fine and doesn't glitch at all when graphing--just when stepping through things with z disabled. It glitches at N0007 with a 1/2" endmill as T01. If I goober the tool diameter to .001, it does not glitch. If I goober it to .125" diameter it still glitches. The move between N0004 N0006 and N0007 in the X/Y plane is .26" just for reference.
    For those less familiar with dynapath, C1 is their conversational programming for cutter compensation to the left. C0 is off, C2 is right.
    Anyone have a guess or possible explanation so I can find a way to correct this glitch? I appreciate any help you can give.
    (1 )
    N0001(T) 1/2 em carbide$
    N0002(9)M03T01S3000E1$
    N0003(9)M08$
    N0004(0)G0X-4.013Y-.4284$
    N0005(0)G0Z3.1$
    N0006(1)X0/Y0/C0Z2.75F5.$ (This is a little strange in my book but the post processor sets x and y to a zero incremental move [that's what the / means] and moves z, turning off cutter compensation for the rapid [C0]. It works though.)
    N0007(1)X-3.7544Y-.4013F20C1$ <---- pukes it out here with the 144 fault. Doesn't matter what cutter compensation type is used.
    N0008(2)D1X-3.7207Y-.3831I-3.7596J-.3516$
    N0009(1)X-3.5378Y-.1574F20$
    N0010(2)D1Y.1574I-3.732J0$... and on for another 400 lines
    Aug 2009
    1573
    Re: Need help with error 144 on delta 20 control
    Quote Originally Posted by Kozmonyet View Post
    ...Tool Diameter .500 would be stored for Tool 1...right? not .125
    Oct 2007
    6
    Well, I resolved it through the back door. Solidworks cam chooses a lead-in radius that is 54% of the tool diameter--should be no problem, However to fix the issue I used 105% of the diameter and it seemed to resolve the issue.
    Thanks anyway
    Aug 2011
    121
    Thanks anyway
    I don't have my manual on hand but I think Dynapath expects to be one cutter diameter (or is it radius?) away from the next move when calling up and turning off cutter compensation. Your solution appears to confirm this.
    RT
  1. Replies: 0
    Last Post: 04-18-2021, 02:38 PM
  2. What type of error : Delta Internal Error![Movement Error]
    By asuratman in forum Mach Software (ArtSoft software)
    Last Post: 04-18-2021, 02:18 PM
  3. Delta 20 programming error
    By NITROCHUCK in forum Dynapath
    Last Post: 01-12-2019, 09:15 PM
  4. Delta 20 Checksum Error
    By davidshearer in forum Dynapath
    Last Post: 02-10-2013, 02:39 AM
