586,096 active members*
3,741 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > ACRAMATIC A2100E / SIEMENS SETUP & SERVICE MANUAL / 7-000-5938IS
    Jul 2005
    107
    Hello
    Does any one has this manual:
    Sep 2008
    100
    Re: ACRAMATIC A2100E / SIEMENS SETUP & SERVICE MANUAL / 7-000-5938IS
    What info do you need? I speek spanish.. if you want send me a email to [email protected]
    Jul 2005
    107
    Hello.
    I have a Cincinnati Arrow 750 EKK Series 2, with all Siemens: servo drivers,servo motors, motor spindle. and Acramatic 2100.
    The spindle is hi-torque 5000rpm spindle.
    I want to replace the spindle with an 8K or 10K rpm spindle that I have as spare part. I have found the proper pulley for the motor, so the relation will be one to one. The spindle motor can goes to 10.000 rpm.
    So,I need to modify (turn off) the SPINDLE ORIENTATION SENSOR, because the spindle's pulley doesn't have the half circle protuberance.
    Logging in Security with service password (worldclass - service) I can change:
    *hi- torque option
    *spindle relation pulleys
    *spindle rpm speed
    *spindle motor rpm speed.
    But I can't find how to "turn off " the SPINDLE ORIENTATION SENSOR so the sensor can be removed from the machine.
    I was hoping to find some answers in the ACRAMATIC A2100E / SIEMENS SETUP & SERVICE MANUAL
    Jul 2018
    Did you ever locate a copy of this manual? I would like to find a copy as well. Trying to revive a 1250c ERM.
    Thank you,
    Matt
  1. cincinnati milacron arrow 500 acramatic a2100e
    By josesanto in forum Cincinnati CNC
    Last Post: 08-10-2018, 01:51 AM
  2. Replies: 3
    Last Post: 05-26-2017, 08:27 PM
  3. new hermes ep control module manual & setup
    By darby96 in forum Engraving Machines
    Last Post: 01-02-2016, 04:10 AM
  4. Siemens drive manual & Schematics
    By hotiron in forum Hardinge Lathes
    Last Post: 07-17-2014, 11:00 AM
  5. Very nice X3 breakdown & setup manual/PDF - in color
    By yantra3d in forum Benchtop Machines
    Last Post: 05-28-2007, 03:03 PM
