587,072 active members*
3,146 visitors online*
Results 1 to 13 of 13
    May 2021
    9
    R Less Than Z in Cycle in XY Plane
    Hi I generated a g-code for my drilling work but ran to this error in mach3
    "R Less Than Z in Cycle in XY Plane"
    and i don't have a clue
    this is parts of the g-code
    G90 G94 G91.1 G40 G49 G17
    G21
    G0 Z15.00
    M3
    G4 P4.0
    G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0
    X0.67 Y0.53
    X0.88 Y1.12
    X0.80 Y1.70
    X1.41 Y2.16
    X1.98 Y2.11
    X2.38 Y1.62
    X2.16 Y1.04
    X2.75 Y1.04
    X3.36 Y1.26
    NOTE: When i change r to a bigger number than z instead of going down and drill and going up it goes up and moves in down
    May 2021
    9
    Re: R Less Than Z in Cycle in XY Plane
    May 2021
    9
    Anyone?
    Sep 2018
    27
    Your position when the drill cycle is called is Z15.0 and the holes goes to Z0.0, if you call a retracion at R-6.00 its makes no sense cause this position is under your start position and even under the bottom of your holes
    What is your holes Z top and Z bottom ?
    May 2021
    9
    Quote Originally Posted by lucaswalker View Post
    Thank you very much for responding
    I changed z to z-15 but still the same error
    and if i change numbers to R+6 and Z+15 it's just goes up and moves in down
    what should i do to make it right?
    Dec 2012
    395
    I don't know what G91.1 is doing ??
    Try this;
    G90 G0 Z15.
    G98 G81 X0. Y0. R6. Z0. F----
    X--- Y----
    X--- Y----
    May 2021
    9
    Quote Originally Posted by Heavy_Metal View Post
    Try this;
    G90 G0 Z15.
    X--- Y----
    X--- Y----
    Hello
    Thank you for responding
    I'v done that and it just doesn't move in z axis no more.
    15362
    Quote Originally Posted by mosator View Post
    You can't drill anything with your code like that
    G21
    G0 Z15.00 ( Z axis is above the part by 15mm )
    M3
    G4 P4.0
    G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0 ( Z0.0=the top of your part so your hole depth is 0.0 deep )
    G81G98X0Y0Z-6 R15F1000. ( Now the R value only needs to be enough to clear your work so normally this would be around 3mm to 4 mm )
    your Feed rate also is way to high also so start for a lower feed rate
    G81G98X0Y0Z-6.0R4.F100.
    X0.67 Y0.53
    X0.88 Y1.12
    X0.80 Y1.70
    X1.41 Y2.16
    X1.98 Y2.11
    X2.38 Y1.62
    X2.16 Y1.04
    X2.75 Y1.04
    X3.36 Y1.26
    Mactec54
    Aug 2009
    1573
    ...R is the reference plane and Z is drill depth. Q is peck distances
    N87 T5
    N88 S2200 M03
    N89 G00 G90 G54 X-146.05 Y-6.35
    N90 G43 H5 Z2.54 M08
    N91 G83 G98 X-146.05 Y-6.35 Z-15.504 R2.54 Q2.553 F447.04
    N92 X-113.594
    N93 X-81.139
    N101 M09
    N102 M05
    N103 G53 Z0.
    N104 G53 X0. Y0.
    N105 M01
    May 2021
    9
    my problem is that if z axis is vertical and when negative goes up how can i drill with this g-code? it just doesn't makes sense
    Aug 2009
    1573
    ...you do not have a G Code problem...you have a Z Axis backwards problem
    Sep 2018
    27
    I think you misunderstand how drill cycles works :
    there is 3 key z position in the cycle :
    1) the Z position when you call the cycle
    2) the Z called during the Gxx command of the cycle, which is the depth
    3) the R which is the retraction position, the position you will go back before doing a new cycle.
    All this can be absolute (G90) or relative (G91) with respect to the initial point (1)
    this could be a correct example of your code :
    G21
    G0 Z2.00
    M3
    G4 P4.0
    G98 G81 X0.00 Y0.00 R2.0 Z-5.00 F1000.0
    X0.67 Y0.53
    X0.88 Y1.12
    X0.80 Y1.70
    X1.41 Y2.16
    X1.98 Y2.11
    X2.38 Y1.62
    X2.16 Y1.04
    X2.75 Y1.04
    X3.36 Y1.26
    Dec 2008
    3122
    You say that your Zup is negative.... then your programming is $hit
    G21
    G0 Z15.00 ....this is initial level must be higher than R
    M3
    G4 P4.0
    G98 G81 X0.00 Y0.00 R-6.00 Z0.00 F1000.0.... R must be higher than Z
    M98 is to return to R, M99 is to return to initial level at the end of each cycle
    Get your machine to be correct... ie all Zs above the part are negative or positive.... Not mixed, as you have.
    To work out axes, normally, up thru the spindle is Z+, the X is the longest remaining, last is Y. Positive direction is as seen from the operators position. I did say normally,
  1. Acramatic 2100 canned cycle on G19 plane
    By tomtomy in forum Cincinnati CNC
    Last Post: 07-21-2016, 12:05 PM
  2. Replies: 11
    Last Post: 04-09-2016, 01:55 AM
  3. Drill Cycle Rapid Plane B769
    By seal1966 in forum BobCad-Cam
    Last Post: 10-17-2012, 09:41 PM
  4. Drill Cycle Pecks from Rapid Plane
    By Miksak in forum BobCad-Cam
    Last Post: 01-26-2012, 06:18 PM
  5. Heidenhain CYCLE 19 Work Plane Tilt
    By ED209 in forum G-Code Programing
    Last Post: 09-05-2010, 05:36 AM
