586,061 active members*
4,414 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD wiring with MB3 and ESS
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Jan 2018
    45
    Re: VFD wiring with MB3 and ESS
    Ok I tried :
    PD000=0
    PD001=0
    PD002=0
    nothing happens
    I tried
    PD000=0
    PD001=1
    PD002=1
    spindle turns on goes to 6000 rpm and stays there, cant change rpm with the little dial
    I tried
    PD000=0
    PD001=1
    PD002=0
    spindle turns on goes to 24000 rpm and stays there, cant change rpm with the little dial
  2. #22
    15362
    Quote Originally Posted by darko9000 View Post
    Ok I tried :
    PD000=0
    PD001=0
    PD002=0
    nothing happens
    I tried
    PD000=0
    PD001=1
    PD002=1
    I tried
    PD000=0
    PD001=1
    PD002=0
    Try the J1 Jumper in the other position
    Mactec54
  3. #23
    Jan 2018
    45
    YES!!
    Switching jumper to 2-3 position and
    PD000=0
    PD001=1
    PD002=1
    was able to start and stop spindle in mach4 and was able to change rpm with dial on VFD
  4. #24
    15362
    YES!!
    PD000=0
    PD001=1
    PD002=1
    Just have to get the PWM setup and you will be set, this will have to be setting in Mach4 which I think you have already done, so just the ESS to get configured so post the photos just as you have been doing, as they show up clear enough to see what needs to be changed
    Mactec54
  5. #25
    Jan 2018
    45
    Thank you very much for helping me get this going!!!
    This is how the ESS looks nowhttps://imgur.com/a/vK0l8TZ
    and mach4https://imgur.com/a/3tJfHFi
  6. #26
    15362
    Check what is under the RPM tab this my be able to be set at 24000 check
    Turn on Forward as well
    So disconnect the Relay from the VFD Drive and now test the 0-10v output with M3S12000 M3S6000
    Mactec54
  7. #27
    Jan 2018
    45
    I cant turn forward on.
    Ok this is where I feel lost.
    I do not understand relationship of ESS pins input, pins output and MACH4 pins input, pins output. I know this probably feels simple to most people on this forum but I cant figure this out.
    I don't know much about electronics so I probably need to find place on the internet that can explain to me like I'm 5 years old
  8. #28
    15362
    Your connections you need right now are outputs, Mach4 outputs a command to the ESS the ESS outputs to your Breakout board then to your VFD Connection
    Your On / Off and speed control are all outputs
    Input is when a signal like say a limit switch makes contact it is this input that tells the control / machine to stop
    If you can't turn on the FWD then it may not be needed, so don't sweat this, as we just have to see what works with your setup
    What about the RPM you don't have indexing so this should be able to be changed
    Mactec54
  9. #29
    Jan 2018
    45
    under mach4 output looks looks like this now https://imgur.com/a/Ot4BJSY
    and under ESS looks like this nowhttps://imgur.com/a/EK47Jev
    If I try to do green check mark on ESS output signals, spindle fwd-enable, I does not want to stay, it keeps resetting.
    I have set max RPM to 24000, is that what you referring to?
  10. #30
    15362
    The that looks ok, except for the RPM line on this config page under the PWM line
    Mactec54
Page 2 of 2 12
  1. MB3 + ESS wiring
    By FSS in forum Stepper Motors / Drives
    Last Post: 05-01-2022, 10:48 AM
  2. ESS & MB3
    By jmm2020 in forum For Sale Only
    Last Post: 10-23-2020, 04:47 PM
  3. ESS/MB3 VFD wiring
    By soorena123 in forum Spindles / VFD
    Last Post: 07-03-2020, 02:22 AM
  4. VFD ? Wiring to ESS/MB3 for Mach4 PWM use ...
    By Hardkiffeur in forum Spindles / VFD
    Last Post: 05-29-2020, 08:06 AM
  5. Wrong wiring or setting with MB3+ESS+MACH 4
    By rajdzos in forum DeskCNC Controller Board
    Last Post: 12-01-2019, 03:14 PM
