586,538 active members*
2,896 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD wiring with MB3 and ESS
Results 1 to 20 of 30
    Jan 2018
    45
    Hi everybody,
    I'm wondering if I can get some help from somebody who might have a similar setup.
    For the past year I have been slowly putting together my CNC and with the help from all the forums including this one, I was able to actually put this thing together. So far everything is working amazingly well. I can load up a program and cut a piece of wood (that's all I have tried so far just cutting hardwood and lumber no aluminum)
    The way I have this thing working is, I will turn on the spindle manually on the VFD and then go to my computer and start the program. All of that is working with no issues.
    What I would like to try to do is wire the VFD to my MB3 board and use Mach 4 to control spindle coming ON at the beginning of the program and turning OFF on the end of the program. I have tried to find some information online but the few things that I have found I did not quite understand, or the person had a different controller board then I have.
    I am wondering if there's anybody here that has a similar setup to mine and can share how exactly they wired their MB3 to a VFD and what settings did they use in Mach4 to have this thing working correctly. I see on my MB3 manual where I must wire the VFD but I am not sure what terminal on my VFD I have to use, and other than enabling Mach4 settings what else must be done to have this thing working properly. If there's anybody that can give me a help with wiring this thing correctly it would be greatly appreciated.
    Darko
    Jan 2007
    626
    Re: VFD wiring with MB3 and ESS
    Hi Darko,
    I have the same BOB but different VFD and I'm using Mach 3.
    I did a drawing for my own benefit, so I attch it here.
    Basically, you need to configure a digital input on you VFB to start when contact closes and stop when it opens, and to accept ( usually ) a 0 to 10VDC speed signal.
    Look in yourVFD manual to identify.
    Hope this helps a bit.
    Attachment 465000
    Jan 2018
    45
    I got help from wessongt on reddit on how to wire it and I got it wired but not sure what to do in mach4.
    i have wired:
    AO on mb3 is going to Vl on vfd
    AG on mb3 is going to ACM on vfd
    CM1 on mb3 is going to FOR on vfd
    NO1 on mb3 is going to DCM on vfd
    CM2 on mb3 is going to REW on vfd
    NO2 on mb3 is going to DCM on vfd
    my VFD settings
    PD000=0
    PD001=1
    PD002=1
    PD003=400
    PD004=400
    PD005=400
    PD006=2.5
    PD007=0.50
    PD008=220
    PD009=13
    PD010=6.5
    PD011= 0
    PD013= 08
    PD014=10
    PD015=10
    PD070=0
    PD072=400
    PD073=0
    PD141=220
    PD142= 9
    PD143=4
    PD144=3000
    does this looks like I'm on the right track? What settings do I need to change in mach4, I have tried few things but could not get spindle to work.
    anybody?
    15362
    Quote Originally Posted by darko9000 View Post
    i have wired:
    my VFD settings
    PD000=0
    PD001=1
    PD002=1
    PD003=400
    PD004=400
    PD005=400
    PD006=2.5
    PD007=0.50
    PD008=220
    PD009=13
    PD010=6.5
    PD011= 0
    PD013= 08
    PD014=10
    PD015=10
    PD070=0
    PD072=400
    PD073=0
    PD141=220
    PD142= 9
    PD143=4
    PD144=3000
    anybody?
    What are your spindle spec's, some of the Parameters you list don't look correct for these spindles
    You also don't use Rev for these spindles
    Mactec54
    Jan 2018
    45
    The spindle is Huanyung 2.2 kw water cooled spindle HY02D223B
    15362
    Before you connect to the VFD Drive you need to check the 0-10v analog Board output to see if it is working in MDI you can test by using a M3S12000 this should be around 5v until you have this working there is no point of connecting to the VFD Drive the wiring looks correct except there should be no reverse connection
    Main Supply Power Single Phase Connection for this VFD Drive is R /L1 T /L2 and Ground For NA connection
    At a guess your spindle motor spec's are
    220v
    400Hz
    8.5A
    24,000RPM
    Here are the Parameters you need to correct
    Note ( If PD011=100 and PD073=100 Are Changed then PD006 and PD009 will also have to have to be changed to a different calculated Number )
    PD006=150
    PD007=20
    PD009=82
    PD010=11
    PD011=100
    PD014=8 ( Acceleration Adjust to suit )
    PD015=8 ( Deceleration Adjust to suit )
    PD023=0 ( Forward Rotation Only )
    PD073=100
    PD120=110
    PD143=2
    PD174=11
    Mactec54
    Jan 2018
    45
    That is the problem Mactec54, I did read the manual I just don't understand it.
    Are this pictures better, https://imgur.com/a/wER8Ve9
    15362
    I could see one thing CM1 N01 is not the FOR Relay you have active for the Spindle On /Off you have CM3 N03 so you have to test this Relay output and wire it correct to the VFD Drive to FOR and DCM
    The pulley settings and the PWM are the main things to set the PWM should be 100
    Mactec54
    Jan 2018
    45
    Ok, i have fixed this now.
    i have:
    AO on mb3
    AG on mb3
    CM3 on mb3
    NO3 on mb3 (the NO3 light on MB3 comes on during M03 S12000)
    No vires are connected to VFD
    I have my meter set to DC
    If I do M03 S12000 in MDI I get 10 mV on my meter touching AO and AG wires
    if I do M03 S24000 in MDI I get 10 mV on my meter touching AO and AG wires
    If I do M05 in MDI I get 30.1 mV on my meter touching AO and AG wires
    If I reverse my meter probes i get -10mV
    I don't understand this, are you referring to this seting.https://imgur.com/a/YNEDIER
    15362
    i have:
    AO on mb3
    AG on mb3
    CM3 on mb3
    Just put your meter so that is beeps when you touch the 2 probes together then check the Relay output, with your meter set like this, the meter will beep for M3 On and nothing when M5 Off as simple as that
    Check in Mach4 spindle settings first before you change that setting, these settings need to be setup in Mach4
    Mactec54
    Jan 2018
    45
    OK! i got something right!
    I did continuity test on CM3-FOR and NO3-DCM and i get beep on spindle ON, and no beep on spindle OFF.
    i also was looking in mach4 (configure-control-spindle) and this page is the only one referring to spindle and this is how it looks now.https://imgur.com/a/iCgr7sN
    Jan 2018
    45
    Ok I tried :
    PD000=0
    PD001=0
    PD002=0
    nothing happens
    I tried
    PD000=0
    PD001=1
    PD002=1
    spindle turns on goes to 6000 rpm and stays there, cant change rpm with the little dial
    I tried
    PD000=0
    PD001=1
    PD002=0
    spindle turns on goes to 24000 rpm and stays there, cant change rpm with the little dial
    15362
    Ok I tried :
    PD000=0
    PD001=0
    PD002=0
    nothing happens
    I tried
    PD000=0
    PD001=1
    PD002=1
    I tried
    PD000=0
    PD001=1
    PD002=0
    Try the J1 Jumper in the other position
    Mactec54
    Jan 2018
    45
    YES!!
    Switching jumper to 2-3 position and
    PD000=0
    PD001=1
    PD002=1
    was able to start and stop spindle in mach4 and was able to change rpm with dial on VFD
    15362
    YES!!
    PD000=0
    PD001=1
    PD002=1
    Just have to get the PWM setup and you will be set, this will have to be setting in Mach4 which I think you have already done, so just the ESS to get configured so post the photos just as you have been doing, as they show up clear enough to see what needs to be changed
    Mactec54
    Jan 2018
    45
    Thank you very much for helping me get this going!!!
    This is how the ESS looks nowhttps://imgur.com/a/vK0l8TZ
    and mach4https://imgur.com/a/3tJfHFi
  1. MB3 + ESS wiring
    By FSS in forum Stepper Motors / Drives
    Last Post: 05-01-2022, 10:48 AM
  2. ESS & MB3
    By jmm2020 in forum For Sale Only
    Last Post: 10-23-2020, 04:47 PM
  3. ESS/MB3 VFD wiring
    By soorena123 in forum Spindles / VFD
    Last Post: 07-03-2020, 02:22 AM
  4. VFD ? Wiring to ESS/MB3 for Mach4 PWM use ...
    By Hardkiffeur in forum Spindles / VFD
    Last Post: 05-29-2020, 08:06 AM
  5. Wrong wiring or setting with MB3+ESS+MACH 4
    By rajdzos in forum DeskCNC Controller Board
    Last Post: 12-01-2019, 03:14 PM
