586,055 active members*
4,357 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas 5C rotary with control box---Air-Hot Alarm
Results 1 to 2 of 2
    Hi there!
    Haas 5C with control box. Single cable, brush type, 17 pin. Worked good. Used it last year, no problem. It was sitting for a while, got a battery alarm. Opened controller, measured old blue battery, only had 0.3V.
    Replaced battery with new one (could not find the same blue, used a yellow one made in japan, the same as other Haas machines have). Now it is 3.10V.
    Since battery replacement, cannot make it work anymore. Push "START" button and the "AIR HOT" message is displayed. Cannot send rotary to home position, looks like there is no communication between rotary and the controller.
    Cable is good, measured all 17 pins from end to end, checked connectors inside the box.
    Are parameters get reset after battery replacement?
    Any suggestion how to check the rotary? Encoder?
    Can the rotary go bad just sitting? What is wearing out inside while doing nothing?
    Searched net, found no cure so far.
    Would appreciate any input, experience with rotary control box and connection problems.
    Let me know what you have!
    Thank you!
    Kev
    Attached Thumbnails Attached Thumbnails IMG_20210228_173947915.jpg   IMG_20210105_155708245.jpg   IMG_20210105_155805593.jpg
    Aug 2009
    1573
    Re: Haas 5C rotary with control box---Air-Hot Alarm
    ...try resetting the controller "Initialize Servo Control to Factory Default Parameters"
    Chapter 2.3 (page 8)
    https://www.haascnc.com/content/dam/...ual---2017.pdf
    goodluck
  1. Haas servo controller Air-Hot alarm
    By JasonR in forum Haas Mills
    Last Post: 03-15-2023, 01:25 PM
  2. Air condition on CNC machine control box
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 10-29-2015, 07:09 AM
  3. black face Haas and red box rotary
    By teamjnz in forum Haas Mills
    Last Post: 01-30-2015, 09:17 PM
  4. WTB: Haas control simulator box
    By dcook1987 in forum Want To Buy...Need help!
    Last Post: 08-04-2014, 11:57 PM
  5. WTB Control box for VH65 Rotary Table
    By Fudd in forum Fadal
    Last Post: 07-14-2006, 12:49 PM
