586,089 active members*
3,876 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Puma 400b Turret setting
Results 1 to 6 of 6
    Hello all long time lurker first time posting.
    I have a 2013 Doosan Puma 400b that was having turret issues. One of our techs removed the whole turret and curvic and now that it is back together we cant seem to find a referencing procedure. Is there a way to just manually unclamp the turret (with a keep relay) and handwheel or manually turn it to tool 1 position and call that home? I could do this on Kia machines or old Okuma Howa VTLs in my sleep, but this thing is breaking my stones.
    Thanks!!
    Kevin Dostie
    Feb 2013
    788
    Re: Doosan Puma 400b Turret setting
    Call me: 973-803-9479
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    Is the turret servo or hydraulic?
    K5.3=0 Hydraulic
    K5.3=1 Servo
    If Servo, use K5.4=1 to override the curvic unclamp
    rotate 360 in both directions using only 2 fingers.
    if more force is needed or if motion is uneven then there are balance issues or mechanical issues. Resolve these first.
    If rotation is balanced:
    Align to "slightly off" from a perfect position of the first 12 stations
    Set K5.4=0 and curvic should clamp while causing a slight "jerk" action of one curvic disk slope sliding down the piston disk slope.
    Hold the turret in location and toggle K5.4 =1, =0 there should be an ever so slight "tick"
    Hold the turret in location and toggle K5.4 =1, =0 and it should feel like it doesn't even move...
    Now pull the BLUE BOOK from the pocket welded into the inside of the electrical cabinet.
    Follow the Origin Set instructions that are on, or near, the Servo parameter page (it looks like Or9.5, but it is actually Org.S for Origin Set)
    Feb 2013
    788
    Here is a sample, but these will not be your parameters...just the procedure instructions
    Turret is hydraulic driven with rotary encoder. I would have called yesterday but didn't notice your response until late. I am also in the east coast (Connecticut) I really appreciate the help.
    Kevin
    Feb 2013
    788
    Hydraulic motor turret is entirely different from servo motor style.
    Various encoders show marker pulse at tool one, others show at tool 12.
    Was turret ever disassembled? when re-assembled, was it done in EXACTLY the right order? (see YouTube Video for hydraulic turret, by searching for DOOSAN TECHNICIAN)
    Strong recommendation: call me 973-803-9479 (any time that is convenient for you)
  1. Doosan puma 1800ttsy turret indexing problem
    By stutay80 in forum Daewoo/Doosan
    Last Post: 04-15-2021, 04:15 PM
  2. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  3. Buying a used doosan puma 480, puma 800l
    By Michael82 in forum Daewoo/Doosan
    Last Post: 09-05-2015, 01:44 PM
  4. Doosan - Puma 240S
    By dartplayer1 in forum Daewoo/Doosan
    Last Post: 09-25-2012, 12:50 PM
