586,058 active members*
3,768 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Just built new router and having motor and or controller issues
    I bought a workerbee CNC machine from Yuyong Industries. The build went well and I can jog the machine around the table using mach3. But there is a knocking sound coming from the motors which is also audible during travel. And if I load and start a gcode (the roadrunner) the gantries shake and and the motor noises become quite violent. I think the problem might be with the controller (NVUM V2 4axis) or the power source… I did notice that the little green light on the power supply was dimming slightly in sync with the knocking noise from the stepper motors. I’ve gone through the same tutorial 10 times over now and I’ve got it all hooked up right… I’m lost
    Attached Thumbnails Attached Thumbnails 3F94513E-04AA-444D-8D97-61422BA8054E.jpg
    Apr 2004
    5737
    Re: Just built new router and having motor and or controller issues
    If the power supply is intermittent, that would certainly cause problems with the motors. Check the wiring to it, and see if you can capture a reading while it's flickering. If you can't track down what's causing it, consider a new power supply.
    Andrew Werby
    Website
    Jul 2018
    6339
    Hi MS - What usteps are you using? Peter
    Jul 2018
    6339
    Hi MS - disconnect the motors and run them on the bench, if the action is smooth then its a mechanical issue in the build and you need to work through the mechanicals and identify the gremlin. You can also disconnect a motor at a time (disconnect both on the gantry) this may identify the gremlin faster... Peter
  1. Home built machine, hypertherm, mach3, G540 cut quality issues...
    By jayrod7387 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-15-2018, 01:52 PM
  2. Issues with home-built machine
    By Jeliassen in forum DIY CNC Router Table Machines
    Last Post: 02-05-2016, 10:19 PM
  3. Alignment issues with Home built cnc router
    By dglasco in forum DIY CNC Router Table Machines
    Last Post: 06-20-2013, 08:18 PM
  4. CNC Router Help please. Motor Controller???
    By Pete75 in forum Australia, New Zealand Club House
    Last Post: 07-20-2011, 12:58 AM
  5. Replies: 2
    Last Post: 02-22-2008, 06:02 PM
