Using Wood WOP 4.5.
We have had good success using the dxf import function in WoodWOP. I can bring in contour lines or hole into WoodWOP using the pdf file. I have even managed to import tool paths from other CAM software as long as I can output the path in a dxf. It took some tweeking in the BPP.ini file to get it to work correctly.
What I can't do is import 3D lines. The woodWOP file is not accepting the Z coordinates from the dxf file. Had anybody else had any luck importing 3D dxf files?
