586,116 active members*
3,366 visitors online*
IndustryArena Forum > CAM Software > UG NX > milling on sketch like creo trajectory milling
    Aug 2007
    224
    hello, I have a question about nx12 .in nx cam can we milling on 2d sketch-like trajectory milling in creo. I am a creo user for the last 15 years but now decide to shift on nx for manufacturing only ..right now trying to learn nx but my mind continues to relate every cycle like creo parametric
    Sep 2009
    78
    Re: milling on sketch like creo trajectory milling
    Hello,
    I am not familiar with Creo trajectory milling. If you describe it I may be able to recommend something close in NX.
    NX 10.0.3
    Aug 2007
    224
    thanks for your reply please check this link for a short video of creo trajectory milling.
    https://www.youtube.com/watch?v=aaF2NosynNg
    FSA
    Sep 2009
    78
    I think I can get you going with a similar operation in NX. In NX you could cut those faces with one operation in NX, it's called Z-Level Profile. It is solids based so you don't even need any boundaries for this path unless you want to use boundaries for trimming. In this case you would select the entire part solid for Part and select the faces you want to cut as Cut Area. For step down you can arc-in/arc-out every level, ramp level to level or stagger ramp level to level. If you want to maintain a nice finish for your final path, turn on Optimized depth cuts. This operation type is for semi finishing and finishing so if you need to rough this part first, you should use Cavity Milling. I don't recall if Siemens introduced Adaptive Roughing in NX 12 yet or not and there have been several releases since then. Adaptive Roughing is an efficient roughing path, in the peel milling style. Anyway, I think you'll really like the NX Z-Level Profile operation. It works great and produces nice paths. In NX 12 I think it cannot do undercuts but that might be in the latest version.
    By the way, keep in mind NX is very geometry centric, very powerful and makes it easy to create great toolpaths that would typically cause mid-range CAM to take more time or even struggle. Typically you will select your solid part for Part and then select the faces you want to cut as Cut Area. 3-5 axis paths, turning and wedm operations use cut area. This methodology is very efficient and eliminates a lot of work when containing a tool path to specific areas. I rarely need to create geometry for path containment. Planar Milling operations are boundary driven like old school paths but do come in handy once in a while.
    Feel free to ask if you have more questions!
    NX 10.0.3
  1. creo 3.0 4 axis cutline milling
    By fsa in forum PTC Pro/Manufacture
    Last Post: 04-01-2021, 11:20 AM
  2. Strange thing discovers creo cutline milling
    Last Post: 12-14-2020, 06:46 AM
  3. post processor gone mad creo 3.0 4 axis cutline milling
    By fsa in forum Post Processors for MC
    Last Post: 05-15-2018, 12:58 PM
