586,096 active members*
3,861 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil x3 no movement on any axis
    I really need some help with this new cnc I just picked up.
    Trying to get it running with Mach 3 but I’m having no luck at all, the bob is connected to my pc with a uc100, ive done all the installations correctly and I get both led’s when it’s connected.
    The problem is setting up the motor outputs, I have no idea what pins are for what because I have no documentation. If anyone has any ideas please let me know.
    Just adding more pictures
    Attached Thumbnails Attached Thumbnails A6CB4D5A-E97E-4DA2-8238-FF58D6B5D231.jpg   A6E700BA-53D7-4FDA-A691-EB97F09EE3BD.jpg
    Jun 2007
    3757
    Re: Syil x3 no movement on any axis
    Look here...
    https://www.cnczone.com/forums/syil-products/409310-cnc-post2399092.html#post2399092
    Probably something wrong in Emergency Stop wiring. The silly spindle cover switch is the first place to look.
    Also aging ES switch contacts get crappy, too. Add a 0.1uF cap across the switch to keep it clean.
    Only use ES in emergency. High surge currents in motor drive board occur when ES released after a stoppage.
    NEVER use it to just stop the machine. You WILL be sorry, in time.
  1. Syil X3 CNC No movement from steppers or Spindle
    By ellisakins in forum Syil Products
    Last Post: 08-29-2020, 10:08 AM
  2. 3 Axis CNC Mill Software for PC - Checking Axis Movement
    By rickwoz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-05-2015, 04:06 AM
  3. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  4. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  5. Jerky Movement - Syil X3 Mach 3
    By Megaplow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-09-2008, 04:10 PM
