586,052 active members*
3,935 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Power Supply/Transformer Question
    Hey everyone, thanks for (hopefully) taking a look at my question.
    I'm converting a PM-30MV machine to cnc. I have a question about the power supply for the motors/drivers.
    I'm thinking of picking up 2 of these (X and Y):
    https://www.omc-stepperonline.com/ye...0Stepper%20CNC
    and 1 of these (Z):
    https://www.omc-stepperonline.com/ye...nd-driver.html
    To power all of that, I'm looking at one of these:
    https://www.antekinc.com/an-10464-10...v-transformer/
    My issue is, everything I'm seeing tells me that I can power the drivers directly from the 64VAC transformer, but I just wanted to make sure. I see a lot of people going the unregulated, DC power supply route (like on the Franco site among others) and wondered why bother with the extra components if you can just run the drivers straight from the AC. Any help is greatly appreciated. Hopefully I've provided enough info.
    Thanks!
    Dec 2013
    5717
    Re: Power Supply/Transformer Question
    According to the specs, that 64VAC transformer would work fine.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    4373
    clearly the driver has a built in rectifier and smoothing capacitor and so you can power it with AC, and as Jim says its well within spec.
    You could also use a DC power supply, any where up to 110VDC. The only advantage I would see is that should you ever decide that you want to replace the driver
    with another, which only has DC input, you are somewhat constrained. Whereas if you used a DC supply then any other driver would be fine. Small issue really.
    Craig
    Thanks so much for the quick replies. I really appreciate it. Sounds like I'll just go with the AC power on the driver.
  1. Microwave transformer built power supply
    By TinkerDJ in forum CNC Machine Related Electronics
    Last Post: 04-30-2021, 02:57 PM
  2. Ferroresonant transformer for power supply?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 09-04-2012, 04:22 PM
  3. transformer for power supply?
    By drescher3 in forum CNC Machine Related Electronics
    Last Post: 04-22-2012, 05:58 PM
  4. Power Supply Transformer Question
    By snooper in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 10:38 AM
  5. control transformer to power supply?
    By bobleecnc in forum CNC Machine Related Electronics
    Last Post: 05-20-2006, 02:42 AM
