586,108 active members*
3,293 visitors online*
    Jun 2021
    18
    Tormach 770MX Z Axis Clearance
    I'm hoping to be able to fit a 12" tall part in the 770MX. Tormach sites the travel as 12.7, so given tool holding and tool height this makes it not seem possible. However, when I check their CAD model of the machine it appears that the distance from the bed to the bottom of the spindle is 15.075". And given that I doubt that the spindle nose can run all the way down into the bed, this seems to make sense. So the question is, could I machine the end of a 12" tall part in the 770MX?
    PS - The part is 12" tall after work holding.
    Mar 2020
    218
    Re: Tormach 770MX Z Axis Clearance
    Would have to be someone with a 770 to answer completely so they could measure but as you noted, Z travel is not the same as Z clearance. Arguably, that is another specification that Tormach probably ought to list on the details page of each machine.
    Apr 2010
    60
    These pictures are on my 770M+. My fixture plate is .7” thick so add that to the tape readings. Id say 14.5” from table to spindle nose, 12.7 to face of a TTS set screw holder. Hope it’s some help
    Attached Thumbnails Attached Thumbnails 947DA0FB-C7F6-425B-A88E-02C06DBEB31B.jpg   6372ABC9-0CFA-4535-8988-5F62AC777E35.jpg   C86A8F0C-3779-42B6-983D-533E028E472C.jpg
  1. Tormach 770MX Usable Bed Length
    By Joz234 in forum Tormach Personal CNC Mill
    Last Post: 06-15-2021, 07:58 PM
  2. PCNC 1100 vs 770MX ??
    By Miserlou57 in forum Tormach Personal CNC Mill
    Last Post: 05-08-2021, 07:41 AM
  3. Replies: 6
    Last Post: 03-07-2017, 05:28 AM
  4. Taig Z Axis mod to gain 4 inches of Z axis clearance.
    By Eldon_Joh in forum Taig Mills / Lathes
    Last Post: 01-11-2014, 11:56 AM
  5. Getting Clearance for the 4th Axis
    By GJeff in forum Tormach Personal CNC Mill
    Last Post: 05-02-2013, 09:23 PM
