586,067 active members*
5,130 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > SSR or mechanical relay to turn on spindle?
Results 1 to 12 of 12
    Aug 2009
    119
    Wondering if it is preferable to use an SSR or mechanical relay to turn on/off my 110v Kress spindle with the controller? Have heard mechanical relays can cause EMI noise.
    I have an old Techo Davinci, retrofitted with Mach 3 and Gecko G540, using the original Techno power supply w/ 5vdc. I'd use the 5vdc for the relay, and mount it in a separate box outside.
    Looking at these 2 relays:
    SSR -Schneider 9AS1D52-5 https://www.newark.com/schneider-ele...30a/dp/91F6493
    Stand alone mech relay - iot Relay https://www.sparkfun.com/products/14236
    Appreciate any advice, electronics is my weak subject, altho I did manage the retrofit, with some good advice.
    24221
    Re: SSR or mechanical relay to turn on spindle?
    Mechanical relays should not be noisy. the pulse from coil switching can be defeated with a diode (DC coil) or R/C snubber for AC coil.
    The SSR should also work just as well.
    The second option does not appear to be a mechanical relay?
    You will experience much more EMI from the motor itself than any relay.
    They are Universal motors.
    Albert E.
    Aug 2009
    119
    Thanks Al.
    I emailed about the IoT Relay to get clarification, but I'm going to get it either way, seems so simple to use
    24221
    Looking through the data sheet, it does show a single SPDT relay as the source.
    Albert E.
    Aug 2009
    119
    Dumb question, but does that suggest SSR or mechanical?
    24221
    It suggests mechanical type.
    Albert E.
    Nov 2012
    1267
    Quote Originally Posted by dixdance View Post
    Those two are both mechanical relays, not SSRs.
    If your spindle is turned on and off frequently, I would suggest an SSR. Otherwise, a mechanical relay will work just as good.
    Aug 2009
    119
    Mostly just want to have it turned off when the program is finished, so I know it's done.
    24221
    Going by the size of the unit, I would guess it uses the PCT type of cube relay.
    I prefer the traditional style of relay, a little larger, but the rating is a little more realistic.
    The pins on the PCT type never appear to have a very high current rating.
    Also the inrush current of a Universal motor is quite high.
    Albert E.
    Aug 2009
    119
    My router 800 watts, 7 amps, thought I'd be ok with 25 amp rating.
    24221
    That is typical running current, the momentary inrush is much higher.
    I am suspicious of the true rating of the typical small cube relays, if this is what the unit is fitted with.
    Especially when you compare them to a traditional control relay rating and design.
    Albert E.
    Nov 2008
    643
    I use SSR when turning routers on. For some reason I had to put a ceiling fan capacitor in parallel in order to get it to work. Don’t recall what it was doing without the capacitor. Keep in mind these routers have electronics for safety reasons like no volt protection. You switch it on and plug it in and it should not start up.
  1. SSR Relay directly to the output?
    By tantemay in forum PlanetCNC
    Last Post: 08-25-2020, 11:47 AM
  2. Solid State Relay (SSR) Question
    By dbtoutfit in forum CNC Machine Related Electronics
    Last Post: 02-21-2017, 10:34 PM
  3. Wiring the SSR SOLID STATE RELAY
    By alhaddar in forum Open Source CNC Machine Designs
    Last Post: 07-07-2014, 12:52 PM
  4. G540/ Laptop controlled / SSR Relay
    By FantomMfg in forum Gecko Drives
    Last Post: 07-11-2011, 11:44 PM
  5. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
